Loader wanted |
Roach
Joined: 30 Jan 2013 Location: Wheeler, IL Points: 280 |
Topic: Loader wantedPosted: 30 Mar 2023 at 3:49pm |
Friend of mine is looking for a good used front-end loader for his 180. Does not have to be Allis but does need all mounting brackets. No trip bucket. Hopefully somewhere in the south central Illinois area.
Thanks in advance.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
troym
Joined: 21 Jan 2015 Location: minnesota Points: 130 |
Posted: 31 Mar 2023 at 7:10am |
i would have a loader on a 185 I'm junking se corner of Minnesota, 507 421 0213
Roach
Posted: 01 Apr 2023 at 11:16am |
troym, thanks for the response and even though you are pretty far away, we will keep you in mind.
190XTLP
Joined: 06 Oct 2009 Location: Jerseyville il. Points: 51 |
Posted: 01 Apr 2023 at 5:06pm |
I have a allis 500 on a XT taking it off works fine 500
00 takes it |
WD45G,WD45D.190XTD,190XTLP
D19LP,WC unstyled,WF unstyled WC styled,220 |
190XTLP
Posted: 01 Apr 2023 at 5:07pm |
618 535 1155
Don Jr NY
Joined: 11 Sep 2009 Location: Waterloo NY Points: 377 |
Posted: 02 Apr 2023 at 4:36am |
Just so you are aware the rear mounting brackets are different for the 180/185 vs the 190xt. the 190xt has planetary drive straight axles and the 180/185 have the drop boxes so the rear brackets are straight back to the rear axle with square U bolts on the 190 and they angle up to the rear axle with round U bolts on the 180/185. Hope this helps. Don Jr.
Roach
Posted: 02 Apr 2023 at 11:51am |
Thanks for the info Don. trying to figure out what it would take to modify it to work.
Appreciate the heads up. Rick
