Loader for a 7080 ???? |
Post Reply |
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2876 |
Posted: 09 May 2010 at 2:29pm |
Did allis have a loader for the 7080s if so what model did they put on them? Did they somewhat hold up for limited use?
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 7429 |
wow, that's alot of hp for a loader tractor,not sure of an answer. can't recall ever seeing one on that big of a unit,at least not around here.
victoryallis
Just looking to move a little manure, snow, and maybe 10 pallets of seed a year. I'm not looking at utilizing the full power of the tractor. That's just what works out best to put it on.
Dale Hardtke
Bronze Level Joined: 12 Sep 2009 Location: Watertown WI Points: 168 |
Allis Chalmers model 470 |
DanWi
Orange Level Access Joined: 18 Sep 2009 Location: wttn Points: 1857 |
Aftermarket dual or westendorf should make something to hold up but if you start using it to bulldoze trees it will make junk.
TexasAllis
Silver Level Joined: 14 Sep 2009 Location: Texas Points: 396 |
Buddie of mine has a woods on a 180hp case. A very heavy well built unit.
Craig OH
Silver Level Joined: 25 Sep 2009 Location: Delta Ohio Points: 78 |
we put this agco allis 884 loader on our 8010 we had to make some brackets but it works great. |
redline
Orange Level Joined: 11 Sep 2009 Location: Collins, IA Points: 1013 |
I would guess the Westendorf TA46 loader like I have on my 7050 would bolt right on. It has been a good loader, but I don't use it to the extent a livestock producer does.
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 987 |
We have a bushhog loader on our 7020. For limited use like you said, it does OK. IMO a westendorf model is a little easier to put on and take off.. As you can see from redlines picture, you have to remove the loader before you can take the side panels off. Our bush hog loader is the same way. Just something to keep in mind..
Gregor
Silver Level Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
We got a Westerndorf TA 46 on our FWA 8070. The 46 is rated for that kind of power. Quickie suppose to make a great loader too. It is nice having a bigger tractor with a loader. I can move a pallet with 60 bags of beans (3000 lbs) with no problem. But with that kind of weight, I try to limit how far. Here's their website. http://www.loaders.com/default.aspx They show the HP rating for each loader. |
Gregor
I forgot to add that I can have the loader off in less than 5 minutes and probably alot quicker if I did it more often. I can get the side shields off, but it is pretty tight.
redline
A TA46 will go on a FWA tractor? I might need to study my 9670 a little further. That would make a nice loader tractor!
Gregor
The TA 46 is tight on there. If I'd do it again, i would have went with a different series. I have a picture of it, but to big a file to post. I think the brackets are different between the series. You can contact westerdorf and they'll tell you exactly what you need.
Post Reply | |
