Little more RPM's for the B
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Little more RPM's for the B
    Posted: 06 Jun 2010 at 7:02pm
Might do my first pull this weekend, 3,000lbs class.
I thought I would bump up the RPM's a bit to get an HP or 2, at least to get within CA territory. What do I need to adjust to do this? Just swap out the governor spring with a CA one?
Charlie
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 8:15pm
Charlie:
Changing the spring is probably the best and most reliable way to change engine speed.  I'm guessing that you'll be pulling at the Woodstock, VA show?  If so, I may be there to watch the pull, and I'll probably go on the tractor ride on Sunday morning if hay allows.  Not sure what I'll bring, although it will be either the C or the D14.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 8:36pm
You can go to the hardware store and get what is called a cot spring. That is the next thing to stringing a wire. If you are pulling a transfer sled the extra rpm's you get won't help much. You get extra horse power only if you can maintain the higher rpm's unless you have changed to a larger bore or stroke or both. The only way you will be able to maintain the extra rpm's is if you spin in the 3000 pound class.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 6:18am
I think they use the sled where people step on at intervals but I am not sure. Standard bore and stroke and I will weigh in around 2400 so it's not loaded down. My first pull so I am just heading over as is to see how it does.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 6:53am
Find some more weight and don't get the drawbar above 15 inches. The front comes up to easy if you don't have a lot of weight on the front. I pulled the C at 13 inches. I used spacers under or over the drawbar to bolt the clevis fast to get the bet balance height. Hook low on a big tree with about six foot between the tree and clevis where you can get good traction to test the balance. Set the rear tire pressure at about 6 pounds. That way when the tractor starts to pull down you will already know how it will react.  You will be pulling against other tractors that will be at 3005 if they can get away with it.
When I was pulling I bought as many hooks as they would let me buy and went down the track with different drawbar settings as well as different air pressures. I also watched the tires on the sled as well as the tires on the other pullers. You can some times get an advantage going where the others have not gone. Other times you will want to be in the longest pull ahead of you exact tracks to get a inch or two longer pull.
Bottom line be aware of all that is happening and by all means have fun.
It is always more fun to win than lose but you can have fun when not winning by learning. I always went home happy.
Edited by Dick L - 07 Jun 2010 at 6:56am
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 7:07am
Oh..I thought you were trying to compete with me and my CA at Weyers cave this thursday!  good luck to ya though!  -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 7:29am
Hey Wes, I didn't know about Weyers Cave, they have their Annual pull then?
Charlie
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 7:45am
Purchase a d 15 series 2 spring fo it
This page was generated in 0.049 seconds.
