Lite narrow front
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Topic: Lite narrow front
    Posted: 21 Oct 2016 at 9:02am
Guys,
I would like to source a lite weight NFE for my WD puller. Any suggestions or sources of information on this subject greatly appreciated, tks
dg
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 9:22am
early WC pedestal ?
Use B/C rims made to fit the WD rim
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 9:33am
Do you know what the weight savings would be, approx as I need to loose about 150 lbs.
Not me personally but the tractor lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 9:50am
I had heard 100 lbs but I am not sure.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 9:52am
My WD weighs in 3450 with me on it (210)
No fenders/pto and just about everything off of it as possible with stock rims and 14.9x28's
Charlie
NA G301 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NA G301 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 12:36pm
if it helps i installed a WC narrow front end . Cleaned, packed bearings in grease less tires and rims  it wt in at 160 lbs and i trimed off rear leadge and removed hand crank shaft
