Likely spots for air in 180 hydraulic system
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: Likely spots for air in 180 hydraulic system
    Posted: 29 Mar 2011 at 9:33am
Our 180 has a problem with air in the hydraulic system, the fluid level is good but every now and then everything will stop working, the loader, three point, remotes, power steering...
I have a feeling it's air in the system getting into the suction line before the pump, eventually after sitting a while it will begin to work correctly again and we won't see the problem for days or weeks.
Anyone want to guess what's going on?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2011 at 9:58am
Exactly where are you checking the hyd oil level??
