Lights on 190XT
AndyL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyL Quote  Post ReplyReply Direct Link To This Post Topic: Lights on 190XT
    Posted: 26 Dec 2010 at 6:41pm
The lights on my new to me XT are pretty dim, almost to nothing, even with a full battery charge, still dim. I know the tractor has been repainted, so I'm thinking its maybe a ground wire or something ? Thanks....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 6:45pm
Nice looking tractor. I don't know how Allis did the lights on the 190, but on the older tractors they didn't have a ground wire. They had to be grounded from the socket back to the tractor and any paint in between grounding points would cause trouble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 6:50pm
Every light on the tractor is the same amount of dim...wasnt thinking, it does use a single wire...
Allis Wd45 190XT 6060 Case 930 1070 1270 Deere 630 .Ford 3000,,1979 Gleaner F2 1978 F2...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 6:51pm
I just noticed you are from Newton, Il. I live in Newton township and if you say Newton around here it is where the school used to be and the township garage is now with the cemetery just 1/2 mile west. Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 6:53pm
Nope, sorry,  Its alittle town down here in southern IL
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 7:05pm
Just a hop and a skip from Illinois Gleaners home town of Willow Hill. I suppose it's possible that the switch is the problem but it should be getting very hot with the dim lights. Get a battery charger(the little ones) and hook the neg to grnd then touch the + to the lead feeding the lights on the switch.May need a wire in the clip to reach in and touch the post feeding the lights and see if that brightens things up. You definately have a bad connection somewhere.My 220 uses same basic setup and it's lights are bright and white.
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 7:40pm
Andy good looking 190xt, I would do what Steve M C/IL said, I'am sure it's simple I would  also unplug the Lights and use a meter on each wire to check supply, if you happened to get to much juice pop goes light.
Also the decals in black look good on that 190xt never saw that before.
Good Luck
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 7:47pm
I just did my new to me ac 160 and the lights were also dim .  fenders  were lose. so  they were getting a poor ground  I tighted them up and the lights were bright
Nate (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nate (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 9:32pm
Good Luck
 At first glance I thought it was a 200 and had to take a double take.  I also noticed the model number is in numeral form instead of spelled out.  Very nice looking tractor none-the-less!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 7:35pm
The decals look like the incorrect ones thare sold on ebay. 190's had a white stripe and black letters and said One-Ninety.
I actually like the looks of the black stripe better.
