Light trucks, gotten so sad
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 6:18pm
Put a few mile on and no problems at all. Topped up the cooling system again and then ran after a skid steer with my trailer hauling it back to the shop. All good so far.
Truck even has a starter dispenser I wasn't aware of:
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2026 at 7:51pm
Forgot the load photo. Skid steer runs but has rodent/wiring issues so cannot unlock the foot pedals to drop boom. Hauled it about 16 miles like this but no issues:
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 3:11am
Broke into this machine yesterday and it's a retirement community for rodents, beetles, and other small animals. The belly pan is almost full of rodent nest which explains why there are electrical problems with the machine. The electronic instrument cluster, (EIC) is an absolute mess having a large rodent nest built against it for several years the machine has sat disused in a barn. The panel does not illuminate at all and this is the soft and hardware interface between human, and machine. Basically it has it's skinners into everything and needs to work for the machine to operate. Here are some quick shots after pulling the panel down:
Rodent nest around hydrostatic drive units. This is not the worst of it:
Not a single fuse is blown in the machine but very little actually works. There is a maintenance bypass switch incorporated that bypasses many of the incorporated safety circuits but this when selected locks out boom and bucket functions.
That instrument cluster is long obsolete and I've found nothing used to substitute. I'm going to work with this one a bit later today but in all likelihood, will be reverting to "relay logic" to get the machine back into service. Thinking I can retain many, (if not all) safety and monitoring features this panel provided. A small digital totalizer, ammeter, fuel, and temperature gauges would be incorporated, but will climb that mountain once at it's foot.
Tomorrow, (Thursday) is supposed to be above freezing so will get the machine outside and give it a good bath with the steam cleaner. Not really dirty or greasy, but a lot of dried dust and of course rodent remains/nest. This should all break up easily with the water stream and the very hot water will kill anything still living, or run it off.....
I installed a new injector pump as the old one was frozen stiff from biodiesel and setting several years and the engine runs well. I can drive it easy enough, but with that EIC inoperable, nothing electrical can be enabled including the boom and bucket functions.
Another adventure begins as they say.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 3:33am
Found a manual for the machine online and got it downloaded. Looking into the manual this instrument cluster should come to life as soon as a body sits in the seat. This starts the self test routine and once that completes, the keyswitch will start the glowplug cycle and the engine can be started. This instrument cluster does not come to life at all so nothing works with the bypass switch in the "run" position. Nothing works when this switch is in maintenance but the engine can be started without glow plug assist.
Looking through an electrical print I see where the 12VDC interlock "Daisy Chaining" takes place and after physically removing the seat to check for voltage at the seat weight sensing switch(s) connectors, it is found to be present. However, the rear switch does not have continuity when depressed. Jumpering the plug to bypass both seat switches gains nothing. Next in line is the parking brake switch which has to be engaged to pass interlock voltage to the instrument cluster. It is present and that 12VDC interlock voltage seemingly runs up to the instrument cluster as it should. This is when I pulled the instrument cluster down and found the mounting cavity a solid nest. I did not check for a compromised wire and stopped there.
Hope to gain on it shortly.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 3:37am
Geez, wasn't paying much attention to what thread I was posting to. Feel free to move it to the Construction Equipment field if desired.
Don't like hijacking threads much myself so feel free to either move or delete if wanted.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 4:44am
Is as pertinent on here as HE Codger. All these fast to obsolete electronics controls set these machines on a date for scrap. Intentional.
The manufacturers not only want faster to build but faster to throw away so will buy more. Was nothing wrong of all mechanically controlled hydraulics or operator systems, just too easily field repaired and less bells or whistles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 11:43am
After cleaning up the board and finding a compromised prior repair to capacitor landings/terminations, I have a couple of lights present that should not be. That said however, I did find a control fuse in the engine compartment blown that is in series with this board so now have all five 12VDC power supply inputs present. Have a single ground present on a termination, but only six of 10 retention fasteners were present mounting the board to it's support structure in the machine. These fastener points were rusty and corroded so they were chased with a 6-32tpi tap and pads on board cleaned with isopropyl and a new, stiff poly brush. Much of the crap has been scrubbed and washed away leaving a clean surface. Have not found any compromised solder runs, nor microchip legs so hopefully a couple of ground wires running to the back of the machine, or their respective terminations are culprit. There seems to be gain had with this project.
I put a call into the dealer I help out with the board serial, model, and revision numbers which were perfectly legible after cleaning. I've asked for a print of the board circuitry so hopefully if they'll respond I can repair this long obsolete thing. A replacement type is over $1K in price so have some room to fiddle and this is kind of different and relaxing to me.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 12:43pm
GREAT to hear PROGRESS !! Used to dread fixing  PC that mice had 'relocated to'.... Used to 'brushcut' 1" paint brushes for  PCB cleaning detail. Once 'clean' would use heat gun(aka hair dryer) to be dry it off, then do it again and once more.
Hopefully you've got real good pictures of the PCB, both sides as well as 'part numbers' on the it. For giggles, toss those number into Google, you might be surprised what comes up.
If the part numbers on the actual chips are easy to read,it'll help if you decide to 'reverse engineer' that board . Having actual wiring diagram of HOW it connects is vital to getting it up and running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 1:24pm
I did try google and found a few still available but in the stratosphere as far as pricing. Also found two places on the internet that state they can repair this but both are $1400+ for the servicem, so not really a contender.
Talked to the owner and they are alright with me incorporating relays, enable buttons, annuciator lamps, and digital/analog gauges in a new aluminum faceplate I can fashion. Don't think I'd have a hundred bucks in the job but do want to see if I can get this original board working first. Going to be ringing out a couple of harnesses that run throughout the ROPS roof that has had prior rodent damage this afternoon. Hopefully a compromised ground wire is all.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 4:26am
Have all five 12VDC inputs to the board and all grounds are present as should be. Calling the board bad at this point. In the research stages of building a new control panel and have a good portion of needs on hand already.
Dropped rest of control panel down and wiring damage is prevalent. Many of the wires with prior repairs are once again compromised. This would explain the lack of lighting in the machine. I cannot get a straight answer whether fuses have been replaced as there has been more than one set of fingers in the pie.
Ignition switch panel dropped down:
I'll get to repairing this later today but have a couple other small jobs to tend first. Starting to fall behind on this one but many times a can of worms once opened is like that.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 5:09am
Rodent damage one of the worst repairs to make. Rotten little buggers are infuriating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 6:25am
Yes they are. I'm going to emulate many of the safety's in the system using strict relay logic. Going to retain the engine shutdown for overtemp, low oil pressure, restricted hydraulic filtration, operator seated, and seat belt fastened also. One feature I will eliminate is the engine shutting down if seat belt is unfastened. However, the second this belt is released, the boom functions will immediately lock. Engagement requires operator in seat, seat belt fastened, and manually depressing a button to unlock the boom functions. As original, the second you release the seat belt, the boom functions would lock and the engine would shut down unless you manually switched a toggle switch to "Service", from the "Run" position. This switch also locked the boom functions.
New Holland responded back with "intellectual property" and cannot/will not provide a print of the CCA so kinda SOL with repairing the original board cost effectively. No worries with me as I'll be removing a single point of failure that puts a machine down and replacing with a logical, and easy to follow algorithmic start/run scenario.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 7:36am
Noticed Rust discoloring on Board Corner, it is possible the corrosion could make secondary circuit connections, make sure the Solder lines and circuit face are not compromised.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 8:04am
Rob... i like a challenge... but your pushing the limit this time !!!!  Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2026 at 9:53am
This really isn't that bad. Pressure washer is getting after it later today as the outside temps are approaching tolerable to get wet..... Have been talking with the owners and now have a formulation in place to meet almost everything as original except the digital display which really wasn't used for anything other than the digital timedown to start engine, (glow plug cycle) and fuel level. Glow plug interval with be taken care of with an annunciator lamp powered by a simple adjustable "on" timer through a small contactor. When the lamp goes out, start the engine. I don't know the operational values of the oil pressure, hydraulic filter restriction, engine temperature, sensors as of yet,  but physical measurements will reveal those values. They could be simple "on/off" switches, or varistors, or there could be a combination of both. I'm going to drive digital fuel level, engine temperature, and hydraulic fluid temperature gauges, along with annunciator lamps for alternator charge, hydraulic filter restriction, engine oil level, (and possibly low coolant level) including engine shutdown if anything other than fuel level and alternator charging are out of allowable tolerance. Many of the needed sensors are already there but I don't know their values, or operational parameters yet. All can be sourced easily to operate with my process rather than the original VLSI circuit card.
Something that will be retained from a safety standpoint is the engine will shut down if the operator gets out of the seat. There isn't a way to lock out the machine movement controls with the engine running. The original function was if the seat belt was unlatched with engine running, the foot pedals controlling bucket functions were immediately locked. The engine would continue to run. If the operator left the seat, the engine would shut down. These feature(s) will be retained to keep anybody from getting hurt, or worse.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 3:22pm
Progress. The circuit card, (instrument cluster) is not seeing operator in seat although voltage input from that wiring run is present to it's input. A jumper installed and all safety features enable, boom unlocks and everything but glow plug enable, and lighting work normal. These of course are different systems so moving to their addressment next.
Awaiting an order of timers, switches, buttons, annunciators, and some additional "Bosch" style five pin relays and sockets. Once this goes back together, operation for the operator should be as original with exception of physical "look".
All the while I'm thinking if I wanted to keep doing this crap, I shouldn't have retired.....
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 4:23pm
I uplined the findings annotated here and more work on the machine cometh. I have found the parking brake to be inoperable when engaging the apparatus. All linkage moves but nothing happens. Received a text back that a son used to operate the machine and seldom released the parking brake so well known to be inoperable. Wants it functional again and doesn't mind the cost now being found it's worth repairing.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 9:55pm
Was able to get the work lamps to light up. Still need to work a bit on tail lamps. The fuse panel in the ROPS was buried in rodent nest and is corroded. I had voltage on the light switch but as soon as you tried to pull any current through the circuit, measured voltage went to zero. This is always a compromise to wiring on either the power, or grounding side. I'd wager there is a wire chewed through for the tail lamps in the rear but I've not investigated that area other than a 48" blow gun and paint stick to remove a former nest and 1/2 carcass of mouse remains.
Owner wants either a loud annunciator, (Sonalert screamer) or flashing lamp to remind to release parking brake. Easy enough to incorporate at this stage and will serve a good purpose.
I did locate the values of the sending units for oil pressure, hydraulic charge pressure, and filter restriction sending units. The oil pressure gauge kit comes with the appropriate sender, the fuel gauge is selectable for the proper resistance readings and has full, and empty calibration capability. The hydraulic fluid temperature, and filter restriction are simple on/off switches calibrated at different values.
This has turned out to be quite a nice little job; albeit expensive to repair. However, the machine will not be stored as has been as the barn has a newly remodeled and separated space for the skid steer, mower, and 4020 Deere tractor. There is a nice 180 Allis out in the yard but I don't know anything about it yet.
Overall, a productive day.
That's All Folks!
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2026 at 11:47pm
I just had an ECU board for a Cat excavator repaired through Ag Express, Cat wanted $6000 for a new one and Ag Express repaired it for under $600.
They do miracles to electric boards!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 5:14am
Are likely available but have yet to do a search. News bulletin noted a GM Light Truck BRAKING system fault TSB is being released. Again electronics games on a simple system, where Severe Cold Temps or other Low Battery conditions are affect Auto Braking Controls, failing Brake Boost operation and or immediate braking FAILURES, 2022-2026 model years. Why is there anything Electronic of Power Brake Boost? Or a Auto Braking system necessity?
Secondarily was an article in CDL Life, as to a DOT Investigative action looking into SIDE Under Run Guarding systems for ALL trailers where an auto could possibly Under Run in a Incident and severely injure the auto occupants. Similar to Rear Bumper changes to semi trailers and larger Bobtail trucks for Under Run accidents. The entire focus is away from Teaching Drivers Education to NOT get involved in accidents or to avoid them. Can see the Human Protective Balloon ideology returning from this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 5:39am
Thanks. I've not heard they do board level repair myself and happy you had success. Did a lot of this type work prior to retiring, but had ample information to know what i was working with. Almost like pulling teeth with this one. The service manual has segmented diagrams but no complete point to point wiring diagram as example. Large holes in the information needed to work with efficiently. One has to find the "Point to Point" terminations with a meter; especially on this CCA.
Corrosion with this machine in the electrical terminations has been terrible and takes time to sort. There have been prior repairs to wiring that have been attacked again in addition to fresh damage further up, and downstream. I understand the machine has sat untouched where it was for at least six years so ample time for small vermin to take up permanent residence.
I'm not a believer in electronics into a construction type machine given the atmosphere they exist within. Manual, or mechanical operation worked for a lot of years pretty trouble free and even a novice could keep their equipment in good repair. Not so much when you have a single board with it's fingers into every fit, form, and function and a single point failure takes the machine out of service. Eliminating this very scenario is my goal with this machine as it's been troublesome in the past; along with knowing these EIC, (boards) were known failure items. To be fair, not really a machine fault in this scenario, but rather atmosphere and care/exposure.
When I finish all automated features should remain intact but isolated into operational segments and easy to t/s in the future should problems arise.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2026 at 5:49am
There are retrofit, or modification kits available to install a later type EIC into this series of machine. Still pretty heavy on cost however.
I found a couple boards used on the internet but still over 1K each. Given they were a known failure item, I'm just going to eliminate the problem altogether. Myself personally have never seen one of these work. I have hauled several in for either service, or trades on new and all the clusters I've seen are inop. Most have a toggle switch incorporated to unlock the boom functions and other wiring workarounds including a pushbutton for engine preheat, (glow plugs) and I could do the same easily; but I'm retaining the automatic functions through a discreet componentry scenario. I'm not counting nickles but rather going for reliabiltiy over anything else.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2026 at 8:54pm
Some of my parts order have shipped but two important timers have not yet. Located a small section of 16ga sheet metal I'll fabricate into a faceplate for gauges and annunciator lamps to protrude through. Going to weld a section of 1" channel steel to the back side of this sheet for the relays to affix to, then belt sand the face smooth and paint it most likely New Holland gray so looks somewhat original. Have all wiring terminations annotated in notes so when parts arrive, should be somewhat easy to interconnect, and implement into usage.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 32 minutes ago at 3:53am
My old SD Ford still has shortcomings. 27 years on the road and mostly obsolete where is nothing generic on the machine to speak of.
Some Years back the Left seatbelt would not extend for use one day, the inertia mechanism had failed so called Ford, NLA as was outside the nine year line to retain parts availability, so tried salvage and ended up sending back fleabay orders or attempts at making a functional one last a while. All failed. The 1999-2002 model year extended cabs used a model specific floor mount, in late 03 changed to a model specific door mount then in 06 or 07 to a seat mount style that redesigned the seat where that would not bolt into the previous versions.
Planned obsolescence as well piss poor design either criteria or considerations where the use of a Generic Seat Belt system across ALL models should have been call of the day. Across the FORD Lines trucks are different than autos, models of trucks are unique for ‘Accessory’ items as this where parts lines are insane spreads of versions values, efficacy.
Had I Not been issued verbal then written warnings as to my seat belt being on yet totally dysfunctional as ceased retracting, had no inertia system function where was worthless for any accident condition I would not ever bothered with this.
Took a new GENERIC HDT Seat Belt assembly from PACCAR where they use a specific contractor company to provide a belt system they use in EVERY machine they sell. I fabricobbled the system into my SD Ford where has retract and inertia system, used OE mount position and even as color is wrong, do not care, have the State Required belt system I have not ever required as do not get stupid in my machines yet can avoid a ticket fir lack of use or faulty mechanism. When I rebuilt my 05 KW I had noted the seat belt system latch was same as my Ford. Minor changes and slipped right into the truck.
Old truck has Air Bags, not certain the system will even still function, doubt the sensors are any further good. More required not ever needed, must protect the idiots junk that cost money and did not ever get used.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 14 minutes ago at 7:11am
You know to think about it, I don't think I've ever seen an air bag deployed in a 7.3L ford.
