light bulbs
rutabagaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rutabagaman Quote  Post ReplyReply Direct Link To This Post Topic: light bulbs
    Posted: 26 Jun 2011 at 2:34pm
Looking for correct light bulbs for headlights and rear lights.  I converted from a 6 volt to 12 volt and I am not sure what to get.  The old 6 volt bulbs for the headlights were GE1133. The rear light bulb was misisng. Is there a bulb I can convert to or do I need to change the sockets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 4:41pm
Take one to your auto parts store and tell them you need a 12v replacement. I found 12 volt bulbs on the rack at the local auto parts place.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 4:42pm
What tractor ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 4:50pm
Originally posted by Tedin NE-OH Tedin NE-OH wrote:
What tractor ???
It doesn't matter what tractor. It uses a single contact bayonet type bulb GE 1133 and he wants a 12 volt replacement.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 5:16pm
27.3 watt (2.1 AMP) 13 volt S8
Single Contact Bayonet Base #1156
Miniature Incandescent  Light Bulb
hth
      B:-)   Dnoym
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 6:32pm
One on-line cross reference says a 1073 is also appropriate. The glass envelopes of the 1133 is different from the 12 volt lamps but the filament centers are the same.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 7:48pm
The 1156 works fine. That's what's in my Oliver 60 head lights. When I had the reflectors rechromed, it made them about as bright as a sealed beam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2011 at 8:26pm
1156 is a little more power than 1133 or 1073 and with the 12 volt current about half the 6 volt current, there's less voltage drop in the wires so there's ggod reason for greater brightness.
Gerald J.
