lift won't lift
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Topic: lift won't lift
    Posted: 20 Sep 2010 at 9:20pm
I just bought a D17 diesel and the lift arms won't raise.  I hooked a cylinder to the remote outlet and that works great but the lift arms just stay down.  What is going on here, I am confused.
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:26pm
does it have factory three point? My d15 II requires the operator to turn a dial to use either three point or remote cylinder. Not both at same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:27pm
No its a snap coupler,  series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:31pm
I believe there is a hose inside the housing that supplies oil to the cylinder. It has a tendency to go bad and leak into the housing after 45 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:34pm
how bad is that to replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:34pm
Check the coupler where the hydraulic hose fits to tractor. Does it have a round Knob on top? If so try turning it and see if it makes a difference.
ps I gotta learn to post pics.
Edited by Brian S(NY) - 20 Sep 2010 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:37pm
The hose to the internal cylinder is not hard to replace. However the way to tell if thats a problem is if the transmision is gaining oil.(since the hose runs through the tranny to get to the cylinder. Check everything else first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:37pm
If you mean the transport valve I've tried turning that in and out and it made no difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:42pm
Yes, the transport valve. How are your fluid levels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:46pm
The hydraulic oil was low so I added about a half gallon.  Didn't check the tranny.  The pump sound like it goes into high pressure standby when the remote cylinder reaches the end of its stroke and if the internal hose was leaking wouldn't it just keep pumping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:52pm
If it was leaking internaly it would eventiually leak out of the transmision releif cap. I had a similar problem on my 15 II but the problem turned out to be the packing on the cylinder not the hose itself. I replased the hose anyway since I had it apart. It leaked so bad that the bucket wouldnt lift and oil would be running out the top of transmision. Id still look in the trasporter valve for a problem. You should be able to dial it back so that the remote doesnt work even when plugged in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:54pm
I'll give it a try and see what happens.  How do I check the hose and the ram for a leak?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 9:59pm
Well if its leaking then it must be GAININING oil somewhere else. In my case it was the transmision. You'll have to check all the levels to be sure.You said you added oil.. that should be enough to make the arms lift.
Edited by Brian S(NY) - 20 Sep 2010 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2010 at 10:03pm
Thanks Brian I'll see what I can figure out.  Got to get it working, want to see if it pulls the plow better than my gaser.
