Lift/lower lever arm
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: Lift/lower lever arm
    Posted: 20 Nov 2023 at 2:30pm
Does anybody know where you can get a lift/lower lever arm or rebuild? The little nib is too small so it keeps popping out of the lower/raise detents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 2:38pm
So, we are talking a D-14-15-17 ????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 3:42pm
My D-14 Troy, was built up with bronze 30 year ago.....using oxy/act torches...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 3:50pm
I fixed the one on my D17 XT by replacing the pin with a 6mm bolt and double nuts. Used the open threaded end of the bolt as the new pin. Was able to stand it up 1/16" taller to make up for the wear on the window itself, which if the pin is worn, the window ledge is too.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 4:18pm
Fixed the one on my D 15 back in 2019 . Then found out you should not leave the lever locked in the up position. Guess it's okay to leave it in the down position ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 5:37pm
Down is good, inbetween OK...
Mine could be locked in 'up' as PO used hydraulics out back for 'something'. Maybe a hydraulic motor ?? There was a 3/8" pipe on left side of hyd pump section. I put pipe plug in it years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 6:43pm
Thanks Jay, that makes sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2023 at 6:45am
Your biggest challenge may be removing the pivot pin that retains the lift/lower lever onto the shaft. It may be rusted tightly in place. I think I had to unbolt the steering column to get things apart and back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 9:26pm
Thanks guys. I was hoping someone made a new or had NOS somewhere. I'd like to eventually restore this tractor. But trying to plow with the lever not staying in the down position made me want to scream. Probably drill it out and do a bolt.
