Lift arms settleing on D15 |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8760 |
Topic: Lift arms settleing on D15Posted: 03 Nov 2010 at 4:36pm |
This question has probably been asked a hundred times on various tractors, but here goes again for the 101th time. What is the most likely fix for lift arms settleing on a D 15? Had a sickle mower hooked up to it with a single acting cylinder for the sickle lift, and that settled as well, only takes about 30 seconds to settle, Thanks in advance, Darrel
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10876 |
Posted: 03 Nov 2010 at 6:25pm |
Could be valve not closing properly.Does your tranny oil overflow at all? If so, it will be cylinder leaking or hose. HTH Tracy Martin
Stan R
Posted: 03 Nov 2010 at 6:32pm |
Leaking hose inside the rear end was our problem with the D15.
darrel in ND
Posted: 03 Nov 2010 at 9:02pm |
Thanks guys. I think I'll check fluids in the morning, and I am sure that I'll find the hydraulic oil low, and the tranny or rear end oil over full, because I topped off the hydraulics today, and and it wasn't long before the arms and the sickle wouldn't raise any more, as if no hydraulic oil. Next question; how to find a leaky (hopefully just a hose) in the rear end? Darrel |
Tracy Martin TN
Posted: 03 Nov 2010 at 9:37pm |
Darrell, Must take off the rockshaft housing. You will need a lift of some kind if you do it yourself without help. Makes it easier with a hoist or cherry picker. I would purchase new packing, new hose and o-ring for cylinder anchor pin, and housing gasket. Not that hard of a job. Just messy. When installing the hose don't twist it while installing it. It may cause it to rub housing or pto shaft. There is a strip made on them to make installation easier by visual inspection. HTH Tracy Martin
darrel in ND
Posted: 04 Nov 2010 at 7:48am |
Thanks, Tracy. One more project to add to the list!! Darrel
