Life after the 426
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 4:48pm
Cummins, Cat, and Detroit Diesel had the business.  It was about as easy to get one of their owners to switch to an Allis Chalmers engine as it was to get a John Deere owner to buy an Allis tractor.  The engine division and corporate management must have been smoking something stronger than tobacco to think other wise.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 4:51pm
Originally posted by ILGLEANER ILGLEANER wrote:
You for sure got it up away from everything. But its hard to put the implement down, give it the throttle,and steer. All at the same time. If you put the implement down before the throttle, it will kill the engine. That is where the foot throttle was nice on the 7000 you could do both at the same time.
                                                  IG
I've always used the PD or the PS and shifted down a gear when turning and keep the throttle at 75% or more.  Then throttle up and up-shift after the implement is in the ground.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 5:03pm
Was there ever another engine model for the big trucks that was released other than BIG AL ?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 7:31pm
Other than on the road I never use the foot throttle. I do like the 190 set up a little better than my 7050 but it's not really that noticeable. Also I think the 8000 series don't seem as well built in the cab as the 7000 series are. More flimsy pieces and parts. The throttle needs a longer handle or like the later ones on the side console.
Wink
I am a Russian Bot
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2012 at 9:10pm
I have literature showing the 2800, 2900, 3400, and 3500 as 'Country and City 'truck engines. I am putting a 3500 MK II engine in a 220 that was on a municipal water pump. The manual that came with it is for a 'On highway engine'.  There were numerous HP. ratings for the "Big Al"
