Left steering on an h4 crawler |
pinball
Joined: 28 May 2014 Location: missouriu Points: 6458 |
Topic: Left steering on an h4 crawlerPosted: 05 Aug 2014 at 6:03am |
I have a h4 crawler/loader and I think my left brake is not releasing all the way. I have the left track off to replace the rear sprocket and to repair the adjusting arm so I have that side blocked up. I started the engine to turn the sprocket so I could get to the bolts better as I took them out but it acted like the brake was still engaged some. is that a hard or easy fix. any ifo is appreciated. thanks norm
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 12 Aug 2014 at 12:05pm |
see post on 653 AC same machine
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Posted: 12 Aug 2014 at 6:47pm |
I SENT YOU A PM TWO DAYS AGO. DID YOU NOT GET IT ? EVEN IF THE CLUTCHES ARE STUCK OR NOT IT REQUIRES A LITTLE PRESSURE ON A BAR TO MANUALLY TURN THE CLUTCH PACK IN ORDER TO REMOVE THE BACK BOLTS. I ALSO PULLED THE RIGHT STEERING LEVER BACK TO SEE IF THAT MADE IT EASIER TO MOVE THE LEFT SIDE.
