LED Trailer lights
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Topic: LED Trailer lights
    Posted: 16 May 2019 at 8:35pm
Anyone have a trailer with LED lights for taillights and turn signals ?
Pros , Cons ? Any input would be helpful. I am thinking about having mine converted over to LEDs
TDF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDF Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 8:51pm
Yep.car trailer. It's a hard life back there in the salty spray. Lasted way longer than I ever got out of incandescent bulb lights. Maybe 6 or 7 years? Maybe longer. Forget exactly when I put them on. Just had to replace one of them because he was down to about 3 LEDs when I'd hit the brakes. Replaced it with another LED. Other side of the trailer is still going strong. Wont be going back to incandescent.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 9:13pm
My goose neck looks like Christmas at night with LED's,very bright burning, mine have burned fatefully for about 10 years now without a failure, guess this will jinks me, I'll have to double check them now! It's the best thing you'll ever do for your trailer, truck will be happier with the lower amp draw too!
Edited by JoeM(GA) - 16 May 2019 at 9:14pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 9:18pm
I've replaced the '1157' bulbs with LED equals on one of my trailers, the other has sealed LED units. Sealed ones are a better deal IF you can keep from banging into things!
When I wire up trailers, I connect INSIDE of the enclosures,. solder and heatshrink. Makes for a neater, better install. I also use 1/2" black polypipe as a 'conduit' to get the wires from front to back.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 9:40pm
I replaced the tail lights on my 18' deckover trailer that I haul hay with. Best thing I have done for that trailer! The LED lights are brighter and the rubber housing seals the salt better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 1:01am
You need to have at least one regular light somewhere in the turn signal circuit or things won’t flash properly unless you get a special flasher.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 1:24am
DOT guys like em. They can and do make you replace the whole light when one led burns out.
sandman2234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandman2234 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 7:02am
That is an issue with commercial truck drivers and ignorant law enforcement officers. There is an "allowable" amount of LED loss that is acceptable. It was a big debate going on when I came off the road, so I never actually learned what they decided was the correct percent of loss. (I am not saying all law enforcement officers are ignorant)
  David from jax
A proud member of the Allis Express movement!
               Northeast Florida
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 1:02pm
Changed any lights I needed to replace with LED - including the Positive ground on my British Motorcycles (just need to buy + ground bulbs) as LED are polarity sensitive .
 On trailers and vibration producing units they lost better as no filament to break
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:41pm
I put LED lights on my car trailer when they first became avaliable over 15 years ago before that every time I took the trailer out I'd fix bulbs they just corroded and quit working. I put sealed LED units on and haven't touched them since every time I hook up the trailer I plug it in and they work.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 8:54am
The sealed stuff don't last out in the salt very long!---where the prongs plug in eats off the first thing and no way to seal salt out. I went back to regular bulbs on all of my trailers. --- Problem now is they quit making bulbs, so your screwed no matter which kind you use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 1:31pm
I tried LED on the truck bed when I repaired it and replaced all the lamps. Darn things would flutter flash and act all manner of weird, turns out has a slight issue in the alternator, charges fine but one diode is iffy, will stay iffy until quits charging and the LED bulbs got replaced with 194s
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 5:37pm
re: quit making bulbs ...
really ? every cheap set($20 for complete trailer wiring pkg) has 2 -1157 and 3 -194s.
 re: salt corrosion
providing the connector and lamps are new, a good dab of 'dielectric grease' will seal the connection. The problem with salt is once you've got ONE grain of it,unless you really,really, REALLY clena EVRYTHING.....well...it does EAT away...
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 7:33pm
in my part of the world when i do an Vehicle Inspection
NOTE:
Any LED lights having over 25% not illuminated .
will not pass dot
  HTH        B:-)        Dnoym
This page was generated in 0.168 seconds.
