LED lights 190XT |
Page 12> |
Author | |||
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5234 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Sep 2020 at 8:11pm |
Forgive me I am sure this question has been on here before. I tried doing a search on the forum but quickly became frustrated. So, I would like to upgrade my 4 sealed beam lights on my XT. I am looking for lights that look factory, not ones that have 4-5 round LED lights in them. Any help would be appreciated.
Robbie |
Sponsored Links | |||
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2473 |
That sight doesn’t have what I’ve seen before. The LED light I saw before looked just like the sealed beam light.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Wink I am a Russian Bot |
Thanks Lonn, those are the ones that I was looking for. My brother Charlie saw those as well. I think I am going to order 2 to see how I like them first.
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Will these lights have the "2 tier" brightness that the originals have ?
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Looks like you need the bolt on back housing to go with it.
Charlie
I haven’t paid attention the lights having 2 tier brightness? Just the inside ones also coming on the second click of the switch. Guess I need to check that out.
Yes, there a 2 bulbs/side that come on in the first position of the rotary switch, but the second position lights up another filament in the "outer bulbs" ?? Pretty sure someone will "confirm or chastise " me on my memory
WD in Australia ![]() Bronze Level ![]() ![]() Joined: 25 Jul 2019 Location: VIC, Australia Points: 157 |
Another option I have found but not tried as yet. LED bulb.
Depending on the light means you can keep original light but get LED benefit.
WD(NF), WD45(WF), WD45D(WF), XT190D(WF), Model U, Gleaner C, All Crop 60, Rotobaler
On mine, the 2 inboard lights come on first, second click the outboard lights come on also. I could see the above option with the first series that only had 1 light?
Charlie
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3926 |
I have them in one of my cubs. It is still 6volt so not real bright, but much brighter than the filament lamps. Now that I think about it, should try it in one of the 7XXXXs 12v hi lo lamps and see what that looks like. |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
The factory used 2 different bulbs. Inners were trapezoid (4411) and the outer were flood (4406) I think.
Gregor ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
I got those style LED's like LONN showed on my 3020. They work great. Much better than the original bulbs. There is no high/low beam to this light. It is either on or off from what I've seen and guessing the same for those. I like the ones with the panels on the light housing as showed by Lonn. Really can't tell their LED's until you turn them on. It keeps the original look. I'd recommend. I also put them on my White 105 and got a few on my R50 combine. Those I have the regular LED's without the panels on the light housing. Really have not noticed any difference in light output between the two.
Flyer ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: TN Points: 457 |
I'm not sure they are all like this but I suspect most are. If you look on the back of the light switch there will be a coil between two of the terminal points. The lights are dim because the voltage to them is routed through that coil on the first setting. The next setting bypasses the coil so the lights see full voltage. The third setting turns on the flood lights. Having said all that, the current draw for the LEDs is much less which makes the voltage drop across the coil much less for "dim" operation so you wind up with essentially full brightness in both switch positions. If you want to fix that, you'll need to replace the resistor on the back of the light switch with something larger.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
The 190XT with dual lights did not use 3 terminal lights with high and low beam.
YES !!!! That's EXACTLY what's on the back of a 100 series light switch
Interesting, always wondered what that thing did. Thanks Flyer. Not only do I want to get brighter lighting, I use the rear plug on the fender to power 2 magnetic warning lights that I place on equipment behind me. When I do that now, if my ride is over 20 minutes it has melted the fuse holder and burn up 1 light switch. With the LED’s drawing less amperage, I am hoping to resolve this issue also.
I don't like the light switch with the resistor coil as I've found the new switches don't last like the old ones because, I feel, they over heat...... Maybe because they weren't made for halogen lights. My 200 burned through two switches until I replaced the high/low bulbs with LED. Also, for those who may wonder, the little doohicky showing the positions of the switch says: OFF, H.L. DIM, H.L. BR., and F.L. That's four positions. I assume H.L. means head light, B.R. means bright and F.L. means flood lights.
I would agree. The reason the switches didn't like the halogen lights is that they were likely a higher current draw (lower resistance) than the standard filament bulbs. The heat dissipated by the resistor coil increases by the square of the current (I2R). So a 10% increase in current would result in a roughly 21% increase in heat from the dropping resistor.
Am I wrong that the original filament bulbs did not have a 2 filament bulb for the "bright" setting like an old school auto/truck headlight ? I just assumed that the "brights" were a different filament in the same bulb getting kicked on
Spoke with Kenny Larson this afternoon about the par-36 lights and said they should be a direct replacement. I think I’m going to pull the tricker and get 4. I was going to replace the flood in the rear but it has the red stop bulb in it and I want to leave it factory.
I replaced the rear flood on mine with a 2-color LED. I have it wired for red for the first two light settings. In the flood position it switches to white.
What year did the red bulb go away on the rear fender light ? Our '68 XT has no red bulb, now that I think about it, neither does the '69 180
Mine is a 1968 and it has it. Yours may have got changed out.
Let me correct myself. Larson par36 fluted lights are flood lights not projected lights. Kenny feels I should get up to 30 feet of light. I rarely do any night time work, I use the lights and flashers driving to fields. My main reason to upgrade to LED is to take the stress off of the wiring and electrical system since I use the rear plug to power 2 magnetic flashing lights I mount on equipment behind me while traveling on local roads. These LED’s are fluted resembling the factory lights which is important to me to keep the factory look. Interesting to know a red/white light is available for the rear. Edited by AC720Man - 26 Sep 2020 at 9:07pm |
Our XT has amber top fender mounted flasher ??
Page 12> |
