leaky injector on 190 XT, need help
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: leaky injector on 190 XT, need help
    Posted: 17 Jul 2010 at 2:37am
My latest addition, a 190 XT diesel, decided to start leaking right where it goes into the head. I pulled the injector (its the #1), and put on a new copper washer, and that didn't help. Still leaking a black diesely oily fluid. Any ideas where to go on it from here?    TIA, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 5:52am
Valve cover gasket........replace it.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 6:18am
       I agree with DrAllis. Had the same problem with are 7000 and though it was the injector and it was valve cover gasket.
                                      John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 10:31am
I guess I shouldn't post questions at the wee old hours of the morning after three nights of baling and very little sleep. I guess you guys figured out that I meant to say that the #1 injector was leaking right  where it goes into the head. But I'll check the valve cover gasket and go from there. Thanks. Darrel
ScottinSWIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2010 at 10:00pm
  Thought I had the same type problem with our 180 but it was the valve cover gasket also
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2010 at 11:26am
the oil from valve cover leaks into the injector bore, then oozes out. If it were only a fuel leak, it wouldn't be black. the copper gasket under the injector doesn't seal fuel anyway, it seals the combustion chamber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2010 at 12:53pm
thanks for the help guys. I checked the valve cover bolts yesterday, and they were loose. I tightened them up for now, but will change the gasket as soon as I can get to it.  Darrel
