leaky injector on 190 XT, need help |
Post Reply |
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8657 |
Posted: 17 Jul 2010 at 2:37am |
My latest addition, a 190 XT diesel, decided to start leaking right where it goes into the head. I pulled the injector (its the #1), and put on a new copper washer, and that didn't help. Still leaking a black diesely oily fluid. Any ideas where to go on it from here? TIA, Darrel
Orange Level Access Joined: 12 Sep 2009 Points: 20970 |
Valve cover gasket........replace it.
allisorange
Silver Level Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
I agree with DrAllis. Had the same problem with are 7000 and though it was the injector and it was valve cover gasket.
John Carlson
darrel in ND
I guess I shouldn't post questions at the wee old hours of the morning after three nights of baling and very little sleep. I guess you guys figured out that I meant to say that the #1 injector was leaking right where it goes into the head. But I'll check the valve cover gasket and go from there. Thanks. Darrel
ScottinSWIL
Silver Level Joined: 30 Oct 2009 Location: Randolph Co. IL Points: 118 |
Thought I had the same type problem with our 180 but it was the valve cover gasket also
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4959 |
the oil from valve cover leaks into the injector bore, then oozes out. If it were only a fuel leak, it wouldn't be black. the copper gasket under the injector doesn't seal fuel anyway, it seals the combustion chamber.
darrel in ND
thanks for the help guys. I checked the valve cover bolts yesterday, and they were loose. I tightened them up for now, but will change the gasket as soon as I can get to it. Darrel
Post Reply | |
