Leaking Sediment bowl-help?? |
Mark in Iowa ![]() Silver Level ![]() Joined: 22 Dec 2009 Location: Iowa Points: 200 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Apr 2010 at 7:22pm |
Suggestions for stopping a leaking sediment bowl on my old Frazer tiller? I put in a brand new cork gasket. Bowl is on straight, still drips quite a bit.
Thanks
norm [ind] ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
wrong bowl or use 2 gaskets might be cracked when tightened
top could be bent from overtightening also
Dave A ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Almond Wisconsi Points: 855 |
check the bail. some times the threads feal tight but the bowl is still loose. Dose it stop leaking when you turn the fuel off. Hove seen a lot of them crack just before they go into the tank. and then run down the bowl
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill |
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
One of mine had a warped top as Norm noted......leaked a LOT and there was no fixing it. Replaced that top and all was fine.
WC, CA, D14, WD45
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22822 |
There is a way to fix it other than buying a new one. I had one that was bent from over tightening and it leak bad. I took it off the tractor and chucked it up in my lathe and faced off the bottom of the casting where the bowl seals. It worked great. If your time is worth anything it's still probably cheaper to buy new. Charlie
NICKMI ![]() Orange Level Access ![]() ![]() Joined: 15 Sep 2009 Location: Greenville Points: 534 |
ive got a d 17 with the same problem I just put a regular 5 cent nickel under the bowl tightend it up and problem was solved good luck
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
As you tighten the bale give the bowl a twist, it helps seat the bowl.
Dusty
