lead paint
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Topic: lead paint
    Posted: 26 May 2011 at 11:12pm
When I am sandblasting or wirebrushing an old piece of equipment I always wonder about lead in the paint, I know most all equipment paint pre-1970s or so had lead. How do you guys deal with lead paint when doing a restoration?
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2011 at 9:04am
Good question. I have wondered the same. I use a 3m full face mask with particulate and organic filters. I'm waiting for more answers.
CT
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:04am
There are two ways for lead dust to enter the body.  It is either ingested or the most likely route is inhaled.  A good particulate dust mask (3M) will remove 99.9% of airborne material, assuming you have put it on properly and have a good seal.  Facial hair around the sealing surfaces of the face will reduce the efficiency of the mask considerably because the air will leak through the gaps instead of pulling the air through the filter.
  If your paint removal process is heating the paint and creating fumes, then you should be wearing a respirator.  One thing most people do not consider however is their hands.
 If you do not wear gloves, and stop to smoke or eat without washing your hands, you may be eating lead dust along with your lunch.
  Common sense is still the key.  When cleaning up the shop, try not to make a big dust cloud with your air compressor, vacuum up the worst of it instead...
Like Mom said, clean your room and wash your hands before you eat!  That advice still goes a long way.
Be careful and God Bless,
Gerald
1955 WD45 we like to call Ruby
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:11am
Get a good mask.
It's not just the lead in the paint that should concern you.
If you have every been to a chemical plant that makes ingrediants for paint you would..................................
Tim in Charleston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in Charleston Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:12am
GT  I think you are writing in code I cannot see what you wrote  all I see is white lines
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:18am
Gerald
Hows that
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:36am
There are two ways for lead dust to enter the body.  It is either ingested or inhaled.  A good particulate mask (3M) will remove 99.9% of airborne material assuming you have put it on correctly and have a good seal.  Facial hair along the sealing surfaces of the mask will reduce the efficiency of the mask considerably because the air will go through the gaps instead of through the filter.
If your paint removal process is heating the paint and creating fumes, you should wear a respirator.  One thing most people don't consider however is their hands.  If you do not wear gloves and stop to smoke or eat without washing your hands, you may be eating lead dust with your lunch.
Common sense is still the key.  When cleaning up your shop, try not to make abig dust cloud with your air compressor, vacuum up the worst if it instead.  Like MOM always said "clean your room and always wash your hands before you eat"  That advice still goes a long way!
Stay safe and God Bless,
Gerald
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:42am
For the homeowner or hobby person you need to take precautions with clothing, breathing protection and cleanup of area, but for anyone who is permitted for business the rules are way more stringent.
 This is for everything from painting a house to residing a building. Lead has become another thing on the list of hazards one must protect no only yourself from but the public. it is not quite to the asbestos problem yet but close, this even in rental or sale of property now as a lead paint report is needed in disclosure.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 12:22pm
Coke-in-MN makes a good point.  Heavy metals such as Lead and Mercury are considered bio-accumulative toxins which means they get stored by the body, so with each exposure it builds up in you only to be released later.  Children are at the geatest risk because of thier small body size.  There is a big effort in industry to remove lead from products and the environment.  With that said, your best defense is good hygene, personal protective equipment and common sense.
GT
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 5:42pm
I am 73 and my Mother is 94. She can see and hear as good or better than me. Most of her life and mine all paint contained lead. Inside of the houses, outside of the houses we lived in. All cars, trucks, tractors, machinery and the toys we chewed on when we were growing up. If lead paint was as bad as some would want you to believe  none of you all would be here because your grand parents would have died before your parents were born. Government people control and funds to pay big wages to people so they can dream up the next scare is what it is about. The next scare means more money.  A few people are in danger of getting ill from lead. As many or more die every year from peanut poison. If you can use the the few that get lead poisoning to remove lead from our lives then why not peanuts. We should stop the raising of peanuts or everyone should wear a peanut mask or be fined.
I painted cars after my regular job for extra money when I was in my 20's. I have been painting off and on ever since and never owned a respirator then or now.
I am not saying for people to not wear a respirator because you just might be the one that could be subject to fume poison of some kind.  I just don't drink the coolaid that is passed out.
Figures dont lie but liers figure.
David (in Mi.) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David (in Mi.) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2011 at 8:42pm
 I am just like Dick in the story above. I am 62 years old, and have ate paint all my life. As a child, chewed on everthing a young boy could get into. As a teen, paint red barns and whatever else. As a young adult, painted daily at local J. deere dealer for several years, and after that i have painted off and on all the way up till yesterday. Never have i been in a ventilated room, always exposed to high levels of fumes no matter what and never have worn a mask, and by the way, i smoke yet.  So for all this i am about to get for this i agree, some people are better then others at fighting whatever hits them. I am certianly not telling anyone else to do what i did, and i wouldnt want them to try, but like Dick said, some people like to find something to complain about, no matter what it is.  Now i am sure i am going to die from something, and i dont know just yet what it is, but i am hoping to be shot by a jealous husband.
