lawn mower
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Topic: lawn mower
    Posted: 02 Jan 2018 at 8:43am
I have a Husqvarna with a Brigs engine. It's been a good machine and mostly trouble free. But here lately it has spells of not charging for a little bit, then picks it back up and then quits again. Tested the battery and it's charged up, starts good and everything works. Have any of you had this kind of trouble? If any of you could give me a place to start sometime between now and spring I would really appreciate it. Don't need it today. Nine below out there and I ain't that stupid..................YET
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:46am
Please insert another g in Briggs. Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 9:33am
could be a bad gground on the reggulator of the brriggs engine ( hay I'm kkkkold from being outside).
usually they're a cast aluminum 'block' with 2 connectors on them, 1 goes to alternator ring coils, the other supplies DC to charge battery  and run accessories.
The module does need a Ggood gground,could be a simple, remove, clean,reinstall.
If you need another you can probably buy a whole rider for less than what bbriggs wants for the reggulator!
Jay
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 6:04pm
Clean all the terminals!!  From the battery to the ignition switch, and then more if you can find them!  Take them off, sand/wire brush/what-ever.  Re-install with that die-electric grease and see it helps??
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2018 at 8:02pm
there are several arangments for the alt. reg . setups but  if your problem is intermittant then it is probley the plug on the back of the key switch needs a good cleaning or swicth replaced ayp switchess are not to expensive
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 7:14am
Thanks guys. I was thinking it might be a ground problem, but I wanted to make sure. This is the first time I've had any electrical problems. Otherwise it's been mainly free of problems.  All I've done to the Briggs engine is change oil, plugs and adjust the valves. I'll put a note here when it gets warm, probably sometime in the latter part of March.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 4:36pm
Jay I got a real chuckle with the g. I wonder how many caught it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2018 at 6:44pm
I was hoping SOMEONE would like my dry humour....
maybe it's too dang k-k-k-k-kold down south ??
Jay
This page was generated in 0.240 seconds.
