Latest tractors D 14 - 19 LP
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: Latest tractors D 14 - 19 LP
    Posted: 23 Apr 2020 at 11:14am
Yesterday stop at 3 different places to pick up tractors and a canopy.
about 1000 miles round trip to OK.
Thanks to Adam for loading me at 9:00 pm.
Some of the trip in the rain was not fun driving.
Will get better pictures still raining here today.
D 14 propane
D 19 Propane
Steve in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 1:49pm
makes me want to get started on my wd45 lp i picked up a couple years ago
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2020 at 1:57pm
Now you just need a 7045 high crop to put that canopy on!
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 7:46am
Might use the canopy for my 7020 High crop.
Work on the D 14LP yesterday.
Had to change out the Coil as it was bad. also they had the polarity wrong for way the battery was connected.
Also put about 30% Propane in the tank.
Last few D 14 tractors I have bought, had the missing tube out of the oil filter.
This one did also.
Pull one from a parts tractor, oil pressure is at 23lb.
Also changed out the starter.
Has power steering and need to work on all the leaks.
Still need to spend time on the D 19. The Propane gauge gasket does leak found that out yesterday.
Pull the tractors off the trailer using my D 15 Propane.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 10:12am
I just sold a set of six d19lp piston and sleeves , have two left if you need any
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 8:40pm
Richard,
 Congratulations on the two new Allis LP tractors!  We really like to see your pictures as you bring these home. Do you have plans for these two?
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 9:19am
Glad you made it home safe Richard! Thanks for stopping by. If it would have been different circumstances I would have given you the nickel tour. Hope it all works out well for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 9:54am
work on the D 19LP yesterday put a new gasket on the LP fuel gauge was leaking.
It needs all the belts they had been removed.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2020 at 10:53pm
You do get around Richard.  You just have to be about the luckiest guy,,,,,,,you're always coming up with strays somewhere to add to the herd.  You're worse than a kid in a candy store.  CONGRATS and have fun!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 7:42pm
I had bought this other D 19 LP early before the swap meet and this weekend we spent time changing tires from a parts tractor that had bought some time ago.
Tires off both tractors where loaded with calcium.
Also removed the wheels off the parts U moline, we had removed the motor out of that for the UTC high crop.
Also installed set of NOS set of Snap couplers on the tractor, had bought these at the last swap meet.
Hook the 4 bottom disc plow on the tractor.
Still have to figure why the Snap coupler lift hydraulics will not hold.
2nd radiator for the D 19LP with 3pt seems to holding water!.
Had put all new belts on that tractor,ordered new radiator hoses this morning.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:20pm
do you have any spare three point hitch parts for the D19 i'm looking for the solid winging crank on the lift arm adjustment.
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 10:02am
Sorry no parts, I am looking for more three points myself
