Late WD or Early WD 45? |
DrPepprman ![]() Bronze Level ![]() ![]() Joined: 30 Apr 2023 Location: Missouri Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Apr 2023 at 10:21pm |
Hello, and I am new here. Just bought a Allis Chalmers tractor at auction this weekend and have an identity question about "Who it is?". The serial number on the rear drive has 155624. From what I have found on here is it can be a late model WD, or early model WD 45. It has WD45 stickers on the front, but has the engine plate like a WD on the right side. My question is, "Is there any other signs to tell it's identify"?
Thanks in advance, Adam ![]() ![]() |
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11781 |
Serial number indicates an early model WD45. But without further investigation, there’s no way to tell whether the engine is a 201 (WD) engine or a WD block with WD45 internals, as the blocks are completely interchangeable.
Edited by TramwayGuy - 30 Apr 2023 at 10:26pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22106 |
S/n 146,607 was the first WD-45 tractor chassis, which would have been in mid-1953. S/n 160,386 was the first 1954 model WD-45. It's not a late model WD as per the serial number. If it has a WD engine or engine block, that was installed sometime in its past. The serial number for the engine is behind the carburetor air hose. The original engine would have said 45-XXXXXX-G. Your engine will say W-XXXXXX- G or K.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7528 |
Early 45 replaced with a WD engine at some point in its 60+ years of existence.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5248 |
Straight or curved shifter out of curiosity?
Curved gearshift (helical gear/constant mesh transmission) occurred at approx s/n 127,000.
Dennis J OPKs ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Overland Park, Points: 542 |
Had neighbor with a late model curved shifter WD. He bought it new & didn't keep stuff very long. Shifted only using the hand clutch, would not want to see the guts of that transmission. Could explain it if he was a Deere guy but he wasn't. (Ford)
Thanks for all of this information. It does have curved gear shifter. It also has a #'W111282K' underneath carb air hose. Looks like I got cheated a bit. Oh well, starts and runs. Did sputter a bit, but found first sparkplug wire broke and not running on all four cylinders. Is there a favorite site y'all frequent to purchase pieces and parts?
I figure a little tune-up, paint, and this wf WD/WD45 mix will work for my garden duties. Thanks again y'all for the info. Adam
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8665 |
May not be as bad as you believe. My dad's original 49WD and my 56 WD45 have been shifted with hand clutch only after a little warm up. The WD since 49 and the 45 since 81. No teeth raking while doing so. Left leg is riding on the step late.
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1414 |
Do you have to use an adapter plate between the the block and transmission if you put a 201 in a wd45?
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3291 |
A clutch is a clutch. Doesn't matter how it is engaged. The hand clutch disengages the transmission. That's what the hand clutch was designed for. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8738 |
Welcome to the forum
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4120 |
No, direct bolt-in.
I ask because at a junk sale I saw a wd 45 sell and there was a plate between the block and transmission. A know it all said it was a wd block and you needed an adapter plate but I didn't think that made sense.
WD-45 DIESELS had a 3/8" or 1/2" thick adapter plate, but not the gas engines.
The curved shifter question was based on whether it was a cobbled together WD/WD45.
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
My dad bought one of the last WD's, except for the engine it was just like the WD-45, even the curved shift lever.
