Late curve stick wd |
Post Reply |
Ol case mike
Bronze Level Joined: 24 Dec 2022 Location: Michigan Points: 10 |
Posted: 12 Sep 2024 at 8:00am |
Is the rear gear ratio same as WD 45 vs curved stick Wd
Orange Level Access Joined: 12 Sep 2009 Points: 20163 |
Everything is the same if it has a curved stick. Straight stick trans and ring and pinion are different ratios.
Ol case mike
I thought it was a WD45 when I bought it curved stick with 45 block but motor has WD internals 1953 I believe is serial number on rear end thanks I was wondering about the rear end if was same as a WD 45 ratio
Post Reply | |
