Late 7060 lights |
Post Reply |
Ben (MI)
Orange Level Joined: 02 Jun 2010 Location: SW Lower MI Points: 737 |
Posted: 27 Jan 2024 at 2:03pm |
I just replaced the flasher module on the 7060. The flashers now work perfectly. I thought this repair might fix the other problem but it didn't. The tractor has stadium lights. When I turn the headlight switch to the second position the right front, rear flood and rear red light work but the left front flood doesn't work. When I turn the switch to the third position all the lights work properly, including the left front flood. The red light is off as it should be. Should I replace the headlight switch to get the left front flood to work or is something else going on here? Thank you!
Edited by Ben (MI) - 27 Jan 2024 at 2:13pm |
Part time farming with a 1980 7060 and 1984 F3 hydro.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3373 |
Pretty sure rear flood should not be on in position 2 with the red light (taillight). As for front, they are hi/low beam. Low beam in position 2 with taillight for road and high beam position 3 with rear work light. Least that's how all of mine are as well as 100 series. Seems to me your left side low beam is out
Ben (MI)
Thank you! You're correct,the rear flood is only on when in position 3. I'm glad it's the bulb, that's much easier than the switch and probably less expensive too. Thanks again.
Post Reply | |
