Late 7060 flashers
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: Late 7060 flashers
    Posted: 29 Oct 2023 at 8:31am
The flashers on my late 7060 serial number 7602 have always been finicky but would come on with a little fiddling with the turn signal switch. Now they won't flash. I have dug in to the parts diagrams and have determined that many changes were made to the 7060 flasher module over the years and for the later tractors the module is not shown in the diagrams but the part number is listed if I do a search. The only image I can find is for a replacement part which appears to be the module and turn signal switch in one piece. My question is, is the flasher module and switch one piece on my tractor? Looking at the tractor I can't make sense of it being any other way.
Part time farming with a 1980 7060 and 1984 F3 hydro.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 8:52am
Yes, the turn signal switch is also the flasher unit. A new one,may need a small wiring change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 9:03am
Thank you Lynn! I'm going to AGCO for this one, one of the times I'm truly grateful that they still support the orange. Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 11:52pm
I had to replace the switch in my 7010 once, it came with an extra wire and instructions on changing the wiring when installing the new switch, I left that extra wire hanging out and installed the switch just like the old one came out, the flashers work fine without changing any other wiring.
