Larger fuel tank for 620 |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Topic: Larger fuel tank for 620Posted: 31 May 2023 at 11:34am |
620 with Onan CCKB. I keep running out of fuel. One task in particular, if I start out with full tank, I am on fumes and worried about driving back home on the road. Anyone ever make a larger fuel tank? Looks like the stock tank is maxed out on width (crosswise). Fwd/aft length, the oil cooler is right there. I think the tank could have been taller? I have already leaned out the main jet adjustment as much as I think is prudent. I keep the blades sharp. Are there things you can do to make the CCKB appreciably more fuel efficient? Another question. How is fuel economy after a re-power with Briggs or Honda? I have a modern 48" OHV machine with slightly smaller tank. Used it a few times and can complete the job with plenty gas to spare. However, this machine is 1/2 the weight. But I do need to run it longer to finish. Thanks.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5489 |
Posted: 05 Jun 2023 at 9:40pm |
The factory tank is as large as it gets. The Onan loves fuel. If you have 3 pt make a simple rack that will hold a spare can of fuel to drop off at the work site. Easiest solution I have
