Land Reclimaton Via Drainage and Excavation |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
Topic: Land Reclimaton Via Drainage and ExcavationPosted: 19 Jul 2023 at 2:41pm |
Here is one of many Fields that had springs and uneven ground.
Uneven to the extent that it made brush hogging uncomfortable. Mower would high center or have the back wheels off the ground. We have Installed drainage pipes with gravel and recontoured the ground.... Hope you enjoy. ![]() ![]() ![]() The dirt area and field below were non usable prior to our reclamation chore. ![]() Edited by Macon Rounds - 19 Jul 2023 at 9:36pm |
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2072 |
Posted: 19 Jul 2023 at 2:56pm |
It's been said that they're not making any more dirt but you may be proving that statement wrong. Looks good, well done!!! Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts. |
Macon Rounds
Posted: 19 Jul 2023 at 3:26pm |
Good analogy....
I grew up on this property and always knew it as a mucky pasture. We're not running cattle anymore so to help maintain the property we gathered up all the old fence and are working to drain and level those areas. Time and money is all it takes.... |
Joined: 11 Sep 2009 Location: illinois Points: 88661 |
Posted: 19 Jul 2023 at 4:52pm |
almost everything falls into THAT Catagory ! |
Macon Rounds
Posted: 19 Jul 2023 at 6:19pm |
Here is another area we have reclaimed....
![]() ![]() ![]() ![]() ![]() ![]() Edited by Macon Rounds - 19 Jul 2023 at 6:30pm |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2580 |
Posted: 19 Jul 2023 at 6:24pm |
Yes Sir nothing better than reclaiming nonprofitable lands. Two years ago I dug 12 feet deep into an artesian spring, set a 3 ft culvert tile surrounded with 50 ton of small round stones. Laid 1200 feet of water pipe from there into my cellar (gravity flow). Then dug a diversion ditch for the overflow spring water and led it into my 3 ponds. That deed gave me 10 acres of hayfield I never had! Plowed last Sept, worked and seeded it April 10-12. Now it’s a beautiful dry useable piece. As said above its caring for your land, time and money well spent.
Blue Skies and Tail Winds
Dana |
Macon Rounds
Posted: 19 Jul 2023 at 6:29pm |
Yea
Some of the land we are just trying to dry up and make usable... there is one valley we are trying to capture water and make spring development at the bottom .... Challenging to say the least.... Water coming out everywhere in spring time. Not so much in August... |
Macon Rounds
Posted: 20 Jul 2023 at 1:35am |
![]() ![]() Edited by Macon Rounds - 20 Jul 2023 at 1:36am |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3584 |
Posted: 20 Jul 2023 at 4:07pm |
Benny, you’re doing it right by using perforated field tile to catch the water at its origins & then drain it to an appropriate exit area.
Gravitational pull from our solar system’s sun combined with our earth’s moon will affect land water tidal levels. Hence, field seeps & other soil moistures will rise during planet alignments. And so, field drainage tile’s flow will increase slightly then too. Water tides are not just for oceans, but all of earth’s waters, even underground, are affected. |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5250 |
Posted: 20 Jul 2023 at 8:38pm |
I will say you have some great tools to work with! Your doing a great job and I’d say your having fun doing it.
Macon Rounds
Posted: 23 Jul 2023 at 11:44pm |
Thanks for the encouragement !!!
Anyone wanting to run some of this COOL equipment. come on over. The sign up list is long but sign up soon to save your spot. 😀 We have worked a long time buying and fixing, selling and upgrading tractors, equipment and tooling... Still have much to learn and much to upgrade... Not sure if that process will ever be completed... Transitioning from Allis Chalmers collector to farmer... What am I thinking ??? W |
