Lack of Adequate Maintenace on D-17
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: Lack of Adequate Maintenace on D-17
    Posted: 16 Jul 2010 at 8:30am
Well,  I've been going thru my D-17 and catching up on all the maintenance that had been overlooked for a long time by the prev. owner.
Some glaring examples:
#1. No element (copper wool) inside the breather on the valve cover.
      No telling how much dust has been sucked into the engine because of this! many
      people never touch these breathers altho they are supposed to be cleaned every
      8-10 hours. What happened to the innards, I haven't a clue. There wasn't even a
      trace there.
#2. I took about a cup of fine Schoharie valley silt out of the bottom of the cup
      on the air cleaner. The good news, the oil was up to the full mark and the screen
      was "clean as a whistle".
#3  The hydraulic oil was very "milky"; a sign of some serious water contamination.
      It would seem to me that the breather for the hydraulics could be the culprit here
      as the screened opening points up inviting the rain to enter easily.
      Any of you guys with D-17s find that breather to be a problem?
      I installed a mushroom style cap that still allows the breather to work altho I
      don't expect to leave the tractor uncovered in the future.
#4  The generator does't "gen" and hasn't for some time.  I'll be looking into that
      as soon as I get some free time.
#5  Both the choke cable and the light switch are rusted fast and have been for years.
#6  Radiator fins were nearly plugged shut which I cleaned out with 100 PSI of air thru
      an air nozzle with an extension and 90 deg. bend at the end.
The tractor runs really well and the P.O. had the head all reworked just before I bought it. I think she will appreciate all the TLC!!
skip(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skip(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 9:34am
my air cleaner, when tipped over, looked like i just ripped into a bag of mortar...just about choked anyone standing around.
the hydro oil didn't  have a chance to get milky, one of the rear cylinders would actually squirt oil out...probably go through 2 quarts/hr
i'm not sure if my generator is charging or not
i do have an aftermarket light that works, but the knob for choke is not moveable, but i can pull on the cable on the backside of the panel.
the radiator fins look okay.
the seat is crap
the fenders are rusted
the muffler isn't secure
and i think the battery is being held in place by an ugly bungee cord.
hopefully it's lifetime with me will be a little easier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 10:23am
Wow, I guess I was luckey?
Mine had been "rolled" years ago; they replaced the fenders but the gas tank and the rest of the tin need replacing badly!
This page was generated in 0.222 seconds.
