L59 Blade Bolts Stuck |
bisenberger ![]() Bronze Level ![]() ![]() Joined: 06 Oct 2023 Location: Webb City Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Oct 2023 at 3:45pm |
I have tried all the things from an old post about getting the blades loose on a Woods L59. My compressor only gets up to 120 lbs and my 1/2 inch impact couldn't brake the bolts loose.
Any suggestions
den/southern illinoi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2071 |
Right or left hand threads????
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88224 |
Michael Crowe ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Kansas City Points: 1726 |
They are left hand threads on ge blade spindles.
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
Take a breaker bar and maybe put a pipe handle extension on it. I've had that work if the impact wrench won't. And as said reverse threads. Good luck.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54287 |
Turn the mower on its back, stick a 2x4 under the blade to act as a stop, big breaker bar, as stated, and righty loosey!
Nevermine. I put a jack under my 3/4 break over and added a long cheater pipe and got them loose. I also made a piece of tubing out of angle iron to slide over the blade to lock it again the housing since one of my blades was broken.
Thanks. I didn't see the responses until I sent my message
sparky ![]() Orange Level Access ![]() ![]() Joined: 13 May 2011 Location: So. Indiana Points: 1787 |
I’ve got 3 Woods mowers. 2 L 306’s and 1 L59. All 3 have left hand spindle threads. I was under the impression that all L series mowers had left hand spindle threads.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5244 |
I use my Milwaukee 1/2” impact gun to get them off. I wish they would have put a sticker on the deck notating the rotation of the bolts.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4102 |
I think my L-306 does have a sticker indicating left hand threads. It's been a darn good mower.
If it doesn’t have a sticker just write it on top of the deck with a permanent marker. I also wrote the size socket it takes for the spindle nut.
