L3 steering issues |
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 634 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Oct 2023 at 1:57pm |
I have a L3 sn26576
I had low hydraulicpressure issues and mistakenly removed a plug for the priority valve looking for the pressure relief. Now i have no power steering. Ive removed and installed the priority valve SEVERAL times and cant find anything wrong with it. The steering hand valve in the cab only has 2 lines which controls a steering valve at rear of the combine. If anyone has had an issue like this id love to know how you overcame it Thanks |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Northern Hoser ![]() Bronze Level ![]() Joined: 19 Feb 2020 Location: Canada Points: 123 |
If the fluid level is sufficient, check the belt tension for the hydraulic pump to make sure it's alright.
Have you lost the other hydraulics as well? Will the header/feeder house lift, or auger swing? Matt |
Its only steering. I dont think theres a problem with the belt because if i lift the feeder house all the way up and hold the button it loads the engine. All other hydraulics work fine. Its either the priority valve or the steering valve i think but I cant figure out how to test either
1984 80780
Probably is local to the steering then, I've never heard of a steering valve acting up, likely a problem elsewhere in the system.
This issue sounds familiar, like within the last year someone else had the same issue. Try a search on priority valve see what comes up. Matt |
Thanks. Ill do that
1984 80780
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Check the flow divider in the end of the pump = the first 3 maybe more - gallons goes to steering and the rest goes to the hyd section.
