L3 oil cooler housing gasket leak
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Topic: L3 oil cooler housing gasket leak
    Posted: 30 Aug 2017 at 7:53pm
Had the gasket start leaking where the oil filter housing mounts to the block on my late L3 with the 670 motor. I replaced with a new gasket, cleaned everything up and used black permetex/gasket sealant. Put it back together and it leaked in a different spot of the gasket. Ruined it taking it apart so I bought another new gasket and installed it dry. It still leaks. What am I missing? Should I use sealant or not? If so, what type? Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2017 at 10:33pm
I should specify, it is leaking oil down the side of the block. It isn't the oil cooler itself but where the housing attaches to the block. Thanks
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 7:29am
I assume you cleaned all the old gasket material off the block and oil cooler. If so then maybe the oil cooler or block was not machined perfectly flat or it has a small crack in it. Let us know what you find.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2017 at 8:04am
We had that same leak on on of our L3's last summer, a real pain to get to and work on. I did use blue permatex on the gasket and got it sealed up on the first try.
Leon B Mo
Edited by Leon B MO - 31 Aug 2017 at 8:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2017 at 9:38pm
I had everything as clean as I could each time. I couldn't find any flaws or rough spots to blame, so i used red permetex and let it set 24 hours, ran it all day today and don't think we lost a drop. Thanks for the help!
