L3, from the inside |
Post Reply |
Leon B MO
Orange Level Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2070 |
Posted: 17 Feb 2019 at 10:05am |
Been doing lots of maintenance on the L3, new lower and upper raddle chains with new drive sprockets, new bushings on throat shafts, new concave, turned the chopper knives, new blocks on the walkers. Had to remove the pan under walkers and one of the walkers to fix them up. At that point one guy could crawl in the front and one guy from the back and shake hands. Just thought I'd post a couple of pics.
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7943 |
Dang got a lot going on there, but now is the time to do it and not in prime harvest time, thanks for the pics
Edited by DougG - 17 Feb 2019 at 11:39am |
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
Nice! I like that dolly you made for the feederhouse. Bet that makes it 100 times easier removing/installing it.
When you say you replaced bushings on the throat shafts, were those the bushings where the throat pivots?
Edited by CrestonM - 17 Feb 2019 at 11:44am |
fastallis
Bronze Level Joined: 13 Nov 2010 Location: Avilla indiana Points: 172 |
I put new front and rear raddles, sprockets in my M3 last year. I wish I would have pulled the feeder house. Would have been easier. It had 4 slates missing in row on the rear chain. It sure does a lot better job on corn with all of them in there. I have heard that there are grease sert for the feeder house pivots but I have never seen them?
CrestonM
I've tried greasing the pivots, but from my experience on 6 machines, I can't ever get them to take any grease. There's a ton a pressure, feels like everything is 100% blocked.
Orange Level Access Joined: 12 Sep 2009 Points: 19499 |
For those of you with L and M series machines who harvest corn and have any sidehills, pay attention. Gleaner cylinder bars are installed 4 in and 4 out. This means when 4 of them thresh they are throwing the material in and the other 4 are throwing material out. Re-arrange that setup to all 8 throwing the material in (or 6 in and 2 out). This helps a bunch when harvesting on any sidehills. It will hurt the capacity a little when on perfectly flat land, but the reduction is so minimal compared to when leaning right or left. It has zero affect on threshing. It helps distribute material to the high side of the combine to keep capacity good. So, with the throat cover off looking in at the cylinder bars, they should look like an upside down "V" in the center to throw material towards the center. This is one of those zero $$$ spent to improve your combines BPH when harvesting on any sidehills !!!!
Leon B MO
Yes, Creston. The bronze bushings are inside the pivot brackets that are bolted to the sides of the machine with 4, 3/8 bolts. There is no zerks on ether of our machines. We did both L3's this year and all 4 bushings were worn through. The dolly uses the same jack bolts from my tractor jacks, so all we did was weld up a frame. It does work pretty well, especially when reinstalling, but I hope we wont need it now for several years.
Leon B MO
CrestonM
Must've just been the older machines that had grease fittings then? I've been around some M2s with them, and the Allis cotton strippers have them as well, but like I said, they don't take grease. Maybe why the later ones don't have them.
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3197 |
The 1978 K2’s pivot bushings have grease zerks. I just replaced both side’s bushings this last fall (2018). The bushing’s grease zerk hole much line up with the housing’s zerk or grease will not PATH properly to bushing.
Maybe other models (F,G,L,& M) pivot BUSHINGS that have grease zerks but will not take grease were not installed correctly, at some point?? Below is an earlier link that shows pics of my K2’s pivots. You can see it’s zerk in housing above bushing. I don’t know about L & M models though. https://www.allischalmers.com/forum/leveling-throat-on-l-m_topic155236.html Edited by AC7060IL - 17 Feb 2019 at 6:18pm |
MACK
While pivot caps are off, replace bolts with grade 5 or redrill and tap to 7/16. MACK
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7980 |
My F2 has zerks and they take grease(pivot shaft)
SteveM C/IL
They don't take grease because they have been neglected for too long.You might be able to remove the zerk and dig out the dirt and dried grease and get them working again.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3440 |
This is an interesting post. I'm in the market for a combine. Was leaning toward a rotary because of my sidehills. May have to consider a good L or M if one comes up.
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
As does ours.
Leon B MO
IBWD, there is a low hour (1972 sep) L3 on Tractor House in Minnesota. Looks like it has been taken care of. I gave it some thought.....but not right now. Also a green stripe in Illinois with the hillside air option on the chaffer.
Leon B MO
IBWD MIke
Thanks Leon, would like to find one close enough to drive home. Minnesota is probably a bit far for me, I'm going to look though!
Post Reply | |
