L3 automatic header height
8070nc View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: L3 automatic header height
    Posted: 30 Oct 2023 at 12:59pm
I purchased a L3 with three position automatic header height controll. The header that came with the combine is an older floating cutter bar header with 2 position sensor. They will not work together
Is it possible to put the three position sensor on this header
Thanks
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 1:18pm
Yes they will work.  Use the middle or MID position on the button that will send power down. THEN when the unit clicks the switch to RAISE power the BLUE wire.  To lower the other switch will click and it must send power to the RED wire.  The Red wires will be/should be, jumped at the harness connector - it takes power to BOTH RED wires to lower. Blue - sky raise - Red (danger) lower.  Blue raise -  Red lower.
The switch should be set to always lower when the head is off the ground - when it touches the ground there will be a 'dead zone' then as the head continues to lower or signals to raise it will click the raise microswitch.   The THREE springs do not determine cutting heights - just how far the back of the head is carried off the ground.  Hope this helps.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 1:22pm
Thats what i needed to know. You saved the day. I may have more questions but thank you very much
1984 80780
1957 D14
616 tractor
