L2 with auto reel speed?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: L2 with auto reel speed?
    Posted: 06 Oct 2011 at 10:21am
How does the sensitivity adjustment knob work in relation to the reel speed? My reel hesitates before it starts turning so that I'm about 5 or 10 feet into the beans by the time it starts to turn. A light flickers when this happens up on the overhead console that is green and I think it says faster otherwise when I stop a light comes on that says standby. Sometimes the reel hesitates even if I haven't slowed up my ground speed.
Wink
I am a Russian Bot
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 10:29am
On the Gleaners I had it worked the same way, also my first TR New holland worked the same way which was kind of annoying at times, my reel speed was also linked to the chaff spreader so if the reel slowed or stopped it would effect the spreader or make it stop, so we usually ran it in manual, on the newer TR they had an additional adjustment where you could dial in the stall speed which solved that problem I am not sure if the newer Gleaners had the same ability or not.
