L2 part needed
doug77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doug77 Quote  Post ReplyReply Direct Link To This Post Topic: L2 part needed
    Posted: 26 Jul 2025 at 5:55pm
Does anybody know it the electric solenoid in the cab under the fuse box on a L2  is still available from agco. I tried NAPA but with no luck. Any help would be appreciated. thanks
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 6:38pm
Oreily auto parts has a 80 amp continuous duty solenoid. I dont see why it would not work. Part number 24401-01. Its nomally open and normally closed. Youll just have to make sure you wire it right
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 7:01pm
What is your serial #? They have two different solenoids. I thought they had two different. Part number 71170617 agco has them in the warehouse.
Edited by ryan(IN) - 26 Jul 2025 at 7:08pm
ryan
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2025 at 10:58pm
Yes any Gleaner contimuous duty solenoid will work - two part #'s available.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2025 at 7:57am
I seem to recall that they upgraded the solenoid over the years. Higher amperage, different vendors, or combine serial number changes. I would get the latest one,if possible. It might have had   a 100 Amp rating.
