KW Project |
Post Reply | Page <1 23456 20> |
JohnColo
Orange Level Joined: 03 Apr 2020 Location: Niwot, CO Points: 1258 |
Never a dull moment in Hermon, MO. Cars can be fixed, wives not so easily. Unless,of course you want... er never mind.
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8166 |
Dave,
Our Condolences to you and your family. Good you went to see him! Truck project will for sure keep you busy! Regards, Chris
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7910 |
BXS or NXS ? Gotta luv them 4 bolt rods! There is a lot of swinging mass @ 2100rpm!
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29235 |
BXS
Going to build as a 6NZ Drop compression, invest in single turbo conversion and either reflash or replace processor. While under the hood clearing rats nests noticed front engine mounts had sagged and split, new replacements ordered along with APTIV(Delphi) connector repair kit. Have a number with broken latches and a few been cut out and wire terminal replaced. Will be at this most of winter Edited by DMiller - 24 Dec 2020 at 6:39am |
DMiller
Thanks to all for the condolences, he is in a much better place now as the pain is gone and he can rest, he and My Dad can enjoy each other's company for eternity. Long life, quite the family and quite the accomplishments given the adversities he faced over the years.
These are APTIV/Delphi connectors Edited by DMiller - 24 Dec 2020 at 8:00am |
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9553 |
Prayers for your family on the loss of Uncle, hope your wife wasn't shock up to much from her accident. You sure have your time planned and looks like your enjoying every minute of it. Merry Christmas to everyone
tadams(OH)
Dave you shouldn't have trouble getting parts shipped to you now that the Christmas maddeness is over.
DMiller
Small stuff already arriving, some pieces set to arrive Monday.
DMiller
Current Status, Both fuel tanks off, rear most mounts back to where will end up, one front mount hanging the other awaiting spacers that will have to be made. Disconnected air tanks and shift back to the fuel tank mount, removed the unnecessary added in tubing and snipped poorly executed battery cable additions.
Need to procure the Battery/Tool boxes rear mounts and get the tank hanger spacers then can await the sleeve puller. Also need to stop by Fastenal and get more 5/8 x 2 1/2 and 3" bolts washers and lock nuts.
Sugarmaker
Dave,
Looks like a lot of my projects! Something has to get dirty or demoed before it can start to come back to life! Thanks for the updates! Regards, Chris
DMiller
Heavy trucks, heavy equipment, even old tractors seem to have taken the brunt of bad mechanic work over the years, this one no less. Instead of cutting down as I expected the air line tubing to have been, they just added more with ever more leak spots and connections. Turns out for the better as move the tanks back to where are supposed to be. Battery work not so much!! Will probably just have cables made to replace the mess on it.
Once I get the spacers and brackets I will wire brush and clear the rust boils from the frame under the cab/sleeper, get out the airless sprayer and do at least those sections prior to installing the battery box and tool box. Then the Left fuel tank will get a hand polish up and reinstall, the right one(compartmented for Hydraulics) is headed to Montgomery Salvage to trade out for a plain right hand tank. Its replacement will receive same as left side then install.
tadams(OH)
Sounds like a long process that will be a big improvement
DMiller
A little scary today, Wife had Second appointment for a 'Mass' detected, third time present where radiologist Believes is a Benign Cyst HOWEVER they go thru a second set of images today and recommended a Biopsy, that to occur 01/08. So pretty quiet coming home where found box on my shop stoop. Buddy dropped it off, said send cash and Keep it, NEVER once had out of packaging in six years. LESS than 10 minutes later including Unpackaging to this, using a 1 1/8" socket and a long 1/2" drive flex head ratchet.
Should have my butt kicked across the state for being SO CHEAP for close to fifty years NOT investing in one of these, laying under trucks tractors, Heavy machines and standing over inverted removed engines flailing like a idiot with a four pound hammer and block of oak. ALWAYS Took FOREVER to get them moving and unstuck, sweat like on fire and blood lettings to equal Dark Ages medicine!!! Again ALMOST ten minutes, ZERO Strain. |
DMiller
And YES, I need to overhaul the 180, I am NOT giving this back, cash ALREADY in mail!!!!
Sugarmaker
Thanks(1)
Dave,
It's all about the tooling! Nice piece that saved you hours. I did a home made puller build for my WD series engines. But that there is a nice unit done all from the top too! Hope things are good with your wife! Regards, Chris
JohnColo
I hope the docs are right about your wife, seems like she has had enough trauma lately. Nice tool! I've been trying to get the piston out of an M crawler so I can pull the cylinder, may have to pull them together. Sure is nice to have the right tools for the job.
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13353 |
Well, Guys I'm an ole Shade tree'er and made up some pullers, knockers' loosers and all kinds of tools but am havin some trouble figurin how your puller worked,,,, Did you bend that 1 1/2" pipe pulling the liners or,,,,,?
DMiller
Legs are spring loaded to swing out
Pin in place to a length appropriate to sleeve length to connect at the bottom and have jack screw length to pull Lower legs solid upper section close to schedule 80 pipewall Remainder of yoke is all machined solid steel parts Has smallish bolt in stubs that grip sleeve at bottom Will take photo with it out Are several variations on the pattern all work similarly |
tadams(OH)
Yes the right tools sure make a job easy.
Sending prayers for your wife's biopsy and everything being negative and Ok.
DMiller
Thanks fellas, she is not much worried, but remains worried.
desertjoe
Aw Chit,,Dave,,I see the TOOL now,,,,Chit, I was lookin at #2,3,4,5 and 6 cause the #1 was kinda dark so I just followed the ratchet up to the tool,,,,,Yeah,,post a pic when you gt done,,,,so I can make me a copy,,,,, (Give me an excuse to use my trusty lathe)
DMiller
This is quite a Brute, hex is 1 1/8" Pins are 3/8" , Small package has two smaller width lip feet.
DMiller
Today was another running day, eye doc visit this time, no issues for Wife, did get my DA out and hit block deck with some 320.
Needs a little further cleaning but my 40 year old straight edge says Good To Go!!
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77236 |
thats one heck of a puller DAVE... glad i didnt have to PAY for it !!
Kind of like a lower ball joint press for car/ truck... dont know how many HOURS i have beat on them with a 5 pound hammer to remove.... Bought a cheap press at HF about 10 years ago... Now they pop out in 2 minutes... and it takes 1 of them minutes to get it setup out of the box ! Edited by steve(ill) - 30 Dec 2020 at 6:01pm |
DMiller
Is a Chunk of Iron, made popping those buggers slicker than snot!!! New they run $550-650 now, when I was wrenching full time, similar was less than $250 but them were tight times, and I was a cheap bustard!!!
DMiller
Still need to clean/clear head bolt holes, get some parts thru Cat as Rocker Arm Shafts and bolts, thread lube, assembly lube and any sealants suggested by them. Will have to order a new head, see how it shows up as for internals(Overhead Cam) and whether or not has Injector cups.
Already started the order from IPD as to piston cylinder kits, bearings, gaskets and seals with a New head spacer plate and full set head bolts.
DMiller
Have the IPD list filled out and ordered, looking at a week out, Cat has the essential pieces for the Head replacement and found a New Head no core in Houston TX, $3300(Aftermarket. Will be on order come Monday, closed today. Four Group 31 batteries are just a call away. ALL New coolant hoses and on engine fuel/oil lines.
By end of engine work already allocated will have close to $9,000 JUST in engine. Once assembled will need to buy a Single Turbo conversion kit, that will be around $4,000. Fuel tank clean outs, inspect standpipes, validate gauge function to cab and Polish Tanks. Transmission has a PTO hanging from it, leaks, will either reseal or remove and reinstall cover over the hole, fill with fresh 28# Syn. 50wt. As I rebuild finances will get into a Full Brakes repair, Shoes, Drums, Slack Adjusters cam bushings, air chambers and frame to axle hoses, all six positions, runs right at $250 a wheel not including seals or bearings or supplemental valve or other work. Followed with Suspension repairs, all eight rear air bags, four axle lines, leveling valve. Set ten new tires, polish rims as can. Last up for function, electrical, re-establish rear lighting, correct bad connectors and plugs, reset hood and get all lighting to Code with wiring weather tight. Full exhaust hang. When get to Aesthetic parts, floor mat comes out, new insulation on floor, New air ride Left Seat, either rebuild right seat base or convert to second new air ride seat, misc. interior trim components. New Sleeper mattress, liner the sleeper tool box floors. At this point need to determine if will Repaint Cab/Sleeper. Misc. trim replacements/additions, what ever small failures occur before get to tow ready
Edited by DMiller - 01 Jan 2021 at 2:21pm |
tadams(OH)
Then it should be warmer outside and ready to travel.
DMiller
Winter should be done by then, or just coming back on!! Wife is considering becoming Snowbird.
She will be 62 in three years come June, and be able to retire too.
tadams(OH)
We have been retired for 12 years and have Grandchildren and wife has a son, sister & brother in Florida. We usually go down around Thanksgiving and do Christmas with Grandkids and plan on staying for 2 weeks, usually around 10 days wife says lets go home and we head home. I would have to get a job or something to do if we went for the winter I would get to bored.
