KW Project |
Post Reply | Page <1 1011121314 20> |
Author | ||
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2476 |
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Sponsored Links | ||
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7979 |
Cat was king until EPA ruined everything. I had a 425hp 3406B for 17yrs. Was simple and easy to work on. Current C-15 Acert is doing well. Wished I had detailed info to do cam timing as is intimidating. Can't be that hard,just don't know. Have changed injectors,wiring harness and adjusted ALL that crap up top....takes a while LOL. As an aside... was reading up on "Rattler" harmonic balancers. They use rollers in bores that really only rattle as the engine stops. Was replacing "peanut" gasket as repair shop had it off and seal was twisted and oozing.....there it was! The cam gear has the "Rattler" technology. Thought that was kinda cool.
BPM75
Orange Level Joined: 11 Jun 2011 Location: Greenup IL Points: 1050 |
Yes the B and C mechanicals are pretty hard t beat, I sure miss working on them Lol. E model and C15 even though electronic are still pretty simple and reliable engines in my opinion. Are you wanting to change cam timing or just set timing after a repair or replacement? |
59 D17 gas nf, 66 XT 190, 69 220.
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29466 |
Only big job with cam gears is setting backlash for that ominous gear train. Only one gear is adjustable and is why the Peanut Cover is shaped as it is to allow access to adjust that gear. As to timing is no adjusting it either is or is not on time, crankshaft gets rotated until drop pin slips into hole in flywheel(required) then with peanut cover off validate the cam gear mark is pointed straight up at the little pointer on top of the housing. Can be 180 off where have to rotate crank one more full rev. Everything else is electronic.
Unlike a Cummins no special can keys or specific model cam gears just TDC and done. |
DMiller
Been after it readying for replacement block arriving this next week. Drive lines down(Short one need support bearing anyway), trans off engine sitting on jack, head and upper structure off so am actually beyond back where all this started.
A few more small disconnects, then mounts and engine to be on floor, after that will raise frame remove the frame tool box and pull trans out from under for DEEP Cleaning and any needed repairs. Frame to be dragged outside, spray down with Diesel then simple green, leave both soak a time, then pressure wash and return to shop as dries out. Trans gets done raise frame, reset under and rehang tool box. Then order a clutch(15" two plate). Then is on to engine as rebuild funds to purchase the machine work and all the materials to reassemble. Will be awhile. Edited by DMiller - 31 Oct 2021 at 5:18pm |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7943 |
Serious, the block is bad ?
DMiller
Is the Only aspect left.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77698 |
blocked the nozzle ports and blew air in Air Compressor oil feed line, Air exhausting behind No 1 Main and High in block, Gallery has to be cracked, have to pull engine fully and remove crankshaft to validate, it IS coming out presently.
Hope you can verify that after pulling the motor.. Would be nice to know for SURE before you jump in with both feet..
DMiller
Inability to see past steer axle and other frame structures made it impossible where so many others in the business agreed, time to drag it out rather than drag it on and get it in the open where can see the problem.
Edited by DMiller - 01 Nov 2021 at 3:53am |
SteveM C/IL
Just to retime after repair/replacement. Not happy paying a shop rediculess prices then having a shoddy mechanic do the work. You would not believe how out of adjustment everything on the top was. I don't trust anybodys work there. Has never been right when someone else does it.
BPM75
Gotcha Steve. Well I think someone posted above about it but it's really pretty simple. Pin the flywheel, align mark on cam gear with notch or grove at top of front cover. There is a tool for setting the back lash on gears, if doing a cam replacement or head gasket I don't really recall having to adj one but if replacing head or completely tearing down front gear train then have had to adj.
As far as quality of workmanship anymore....we could have a whole other post about that! Lol. Majority of these shops anymore can't find help let alone good help. I've been working in shops for almost 27 years, truck dealership, CaseIH dealer and a company shop, same story no matter where. It has definitely got worse over the years. And sometimes even a good experience mechanic will make a mistake but it seems like there are more flunkeys than experienced anymore. And it's not going to get any better, very few of the younger generation want to go into this line of work, and alot that do already know everything and don't want to listen. |
DMiller
Engine on the floor, need to strip it fully and then get it out of the way.
JohnColo
Orange Level Joined: 03 Apr 2020 Location: Niwot, CO Points: 1258 |
Another case of two steps forward and one step back, although lately it looks like it's been just 3 steps back. Good luck on the future engine.
DougG
So what was the verdict on the engine Dave ?
DMiller
Not got the block inverted to remove crank yet, will not know until then.
DougG
OK,, thanks,, in life - its always something
DMiller
Had a Charity event today, motorcycle ride event for children with less advantage. Spent all day working it.
DonDittmar
I am watching this thread close LOL. This issue has me puzzled and I am interested in seeing what the root cause is....
farmboy520
Orange Level Access Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
It's like a good detective book or show, can't wait to find out "who" done it.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
DMiller
Crankshaft hanging on the hoist chain, did some other work, stripping block to get to where can get to the Main journals and inside the block.
Clutch was B.A.D. bad, pilot bearing was all but at self destruct mode so I dare suspect someone up above was hiding the issue from me to MAKE me pull the engine out. Left Rear Motor Mount cushion steel side is broken, finding all manner of failures just awaiting some idjit as me to put this behemoth in gear on the street. So bottom line is I found the Issue. Mains. Set a piece of Red Plastigage on the crank with the block on its head side, eliminated the need to block and jack as I had tried on #5 main to get a reading which was within spec, is not now. Red plastigage did NOT squish at all on #4(Thrust) and #7(flywheel weight), puts the bearing clearance Over .010, likely closer to .015 and in NO WAY would this have been able to support Oil Pressure. Did some digging where I had no access early on until around March/April to get on SIS Cats 'Service Information System' site. Had taken a Photo of the Old Bearings to Order my IPD Parts, did not realize they expected ME to know what was in the engine and would tell them not by bearing crossover numbers but actual sizing, I gave them Bearing Numbers. So the engine had 4W-5700 Main shells, labeled 063OS(0.63mm) Or for us Murican Idjits, around a .005 Inch 'Oversize'(OS), IPD sent me STD's. Monday will begin orders for OEM CAT Bearing shells, Rods and Mains, as I am not really happy with IPD currently. Will still use their seals and gaskets as have their sleeves and pistons to reinstall. Rear Main seal was oozing so an out of frame it is. With the Crank out I can fully Mic it, then get the block cleaned and sparkly along with other pieces, so can paint this backstabber before goes back into a CLEANED up Truck Frame with new rear mounts. Once get back calmed and cleaned will post photos tomorrow. God does look after the Idjits, gave me a one final chance before spit that clutch all across the highway. 15.5" Two Plate Eaton. Will also install Reman WP, Reman Fuel Transfer Pump along with other small concerns that could have bit me really hard later. Edited by DMiller - 20 Nov 2021 at 7:39pm |
DMiller
The Clutch:
Rear Main and bearing check The Good Lord will give us alternate chances, owing to our own decisions on good or bad. Clutch could have grenaded like a bomb or bound tight as a welded assembly.
Edited by DMiller - 21 Nov 2021 at 5:56am |
Red Bank
Orange Level Access Joined: 18 Apr 2018 Location: Germanton NC Points: 1049 |
I agree with you there was a reason you had to go through this. Do I understand correctly you can reuse the engine block? I was afraid you were going to have to replace it.
DMiller
Block is fine as best can see, did purchase one as a Just In Case but will sell it as get this reassembled. Also made a error as to mm/in, is .025 Undersize crankshaft.
DMiller
Biggest news of the day, the project may end up in someone else's garage as Wife has made the decision will be a Divorce by January, as soon as all the Family stuff she scheduled is completed into December. Entire Farm will be gone by spring along with all the trappings we have assembled. Will be back to where I was in 1975 only now will be retired instead of training for a new job. 47 years on my own and 37 years with one gal.
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2335 |
I was gonna say,, need to reseal the front and rear structure since you are already this far in,,, then I read last entry, so, is the project jus gonna get moved? or hafta be sold?
Big D won't happen that fast, unless ya'll have already agreed on everything....I been at it since June.
DMiller
I was figuring will be at least until June to get it done, the truck may be drivable in a month or two depending how hard I feed the CC bills. But ONLY drivable to load up to move, is pretty well worthless beyond a salvager right now.
DMiller
Spoke to a number of Cat techs since
Seems the 4W oversize is for bearing bores but a standard crank, I need to bore gauge the full seven to see if all have been resized, then check the additional block I bought as it may be STD bores and use the new Std Bearings in it sell the OE block. Gets ever more confusing!! |
DonDittmar
2436718 is the main bearing kit from CAT in STD size. Good luck finding them. 3400 series main bearings have been on eternal backorder for a while now. The kit comes with all of the main bearings plus the thrust bearings.
DonDittmar
Pilot bearing is a standard 6306 bearing. I am guessing you would want a 308925-20 clutch, that was is rated at 1860 torque. 308925-25 is rated at 2050 torque. 308925-82 is rated at 1700 torque. Dont make the mistake of going with the heavy clutch. You want the clutch to be the weak link. Select the clutch that matches your engine torque rating
DonDittmar
10r2356 is the CAT reman flywheel. 1425868 is the CAT rear main seal. You will need the installer for the rear main. It is a unitzed seal.
