Kohler k301s knock sometimes |
AllisChalmers912
Joined: 15 hours 60 minutes ago Location: Middleburg PA Points: 3 |
Topic: Kohler k301s knock sometimesPosted: 15 hours 54 minutes ago at 6:36pm |
I have a Kohler k301s out of a Allis Chalmers 912H and I just got it running again after I put a new crankshaft and new connecting rod and piston rings in it and there is a knock after it gets hot but it only does it here and there. It goes away at full throttle and at lick half throttle then comes back after a little run time. I idle it back down and it runs fine for about 15 seconds then knocks again. Anyone have any ideas?
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6119 |
Posted: 10 hours 48 minutes ago at 11:42pm |
First and foremost, make ABSOLUTE CERTAIN that your flywheel is NOT LOOSE. They can feel tight, and still wander, and sometimes they'll develop a totally invisible internal crack, that under the right conditions, will expand and release force in the taper. In MOST cases, the cast iron flywheel will stay together fine under 'normal' engine governance, but I've had one that had an invisible crack open up at a 'slightly above factory governed speed' once, and I caught it before it came apart... The K301 had balance weights (balance gears) that spun opposite to crankshaft direction to counteract primary imbalance. They need to be shimmed and timed properly on assembly, and if they've got wear, they'll be sloppy. When these gears aren't done right... and sometimes when they are, the'll come unglued and go on a lateral vacation, leaving a picture window in the block. Usually, the warning is a rattle or knock at low speed/partial load or idle. Most likely NOT spark knock, although these flatheads WILL, given enough of a load. air-cooled flatheads develop hot spots pretty easily... but what you describe just doesn't sound like preignition to me.
AllisChalmers912
Posted: 4 hours 52 minutes ago at 5:38am |
Thank you for the answer Dave. We are going to look at the valves today and if we see nothing wrong we are going to tear it down again and look at the balance gears and see if we can find what the issue is. We may even take a good look at the flywheel to see if it is cracked.
