KOHLER- K301 ?
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Topic: KOHLER- K301 ?
    Posted: 30 Sep 2016 at 7:38pm
The Kohler K301 in my 712H wont start, I have fire to the points but the points wont fire, does that mean the points are bad?
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 8:27pm
They might just need cleaned up. Take some fine sandpaper to em.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 9:10pm
I tried that, and they fired 1 time then no fire again.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 10:31pm
is there power to your coil? make sure your battery wire from key or on - off  switch has power
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 3:21pm
I found trouble, it was just a corroded wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 6:11am
Glad you found it !!
I learned long ago to replace 100% of the wiring on 20-30-40-60 year old machines.... Odds are real good MORE than ONE wire IS corroded....
If you cut the wire, strip and see 'blackish' copper wire not shint clean copper, replace them all. Moisture(water + chemicals) has 'wicked' into the wire. It's only a matter of time before 'funny things' happen or 'it just dies'.
To virtually eliminate that, before you put on a connector, slide 2 pieces of heat shrink tubing on the wire, then after you crimp on a connector, solder the wire to the connector. This fills in the wire strands makes it solid. Now slide one HS tube back over the crimp, heat and shrink.let it cool, then pull the 2nd one over and heat it. Done right the 2 layers of HS will make the crimp/insulation area waterproof.It also strengthens the joint ,so less chance vibration will damage the connection.
Jay
This page was generated in 0.143 seconds.
