Kohler engine oil
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: Kohler engine oil
    Posted: 12 Jul 2020 at 4:18pm
Ok was going to change engine oil in my Kohler 718 lawn mower.It has had break in oil in it so now time to put new oil in. Now the problem i stoped and bought oil but it is 15/30 synthic .The weight is ok but what do you guys think of the synethic oil in a lawn mower???? Thanks Dave
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 4:11pm
Works but for the short duration between changes mineral based oil and change more often should work at lower cost
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 5:57am
synth will have a better 'high heat' tolerance.
JD says to use SAE30 in the TT40 hydro units , even though the mfr, tufftork, says to use synth.....anyone wonder why JD tt40 fail ?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 5:27pm
I have synthetic in all of my mowers including the ZT. Seems to work fine in all of em'...
Steve@B&B
