keystone turbos,gas,any used one |
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1018 |
Topic: keystone turbos,gas,any used onePosted: 13 Apr 2015 at 8:43pm |
found an ad on bolt on turbos for gas tractors from keystone turbo,they have a kit for many different tractors,allis one fits wc wd wd45 d17,looks great,has any one have tried one yet, www.keystoneturbolic.com
NDBirdman
Posted: 13 Apr 2015 at 10:07pm |
Could not get that link to work, but this one does for me:
http://www.keystoneturbollc.com/ I wonder how my stock 36 WC would handle this? Make it a parts machine? LOL Edited by NDBirdman - 13 Apr 2015 at 10:13pm |
VFDfireman
Joined: 11 Jan 2013 Location: South Dakota Points: 414 |
Posted: 14 Apr 2015 at 12:24pm |
Seems to imply that the existing carb on a wd45 would be used....I didnt think it could handle much more air without running lean.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 15 Apr 2015 at 7:12am |
You can't get much with blowing through a carburetor. Not only is that a problem of explosive gas mixture leaking at the throttle shaft. The floats will collapse at anything much over atmospheric pressure. It can be made to work, but a lot of things need to be done to eliminate the inherent problems.
Butch(OH)
Posted: 15 Apr 2015 at 7:20am |
Blow through can work but not the best set up for a lot a reasons, a couple of them already stated. I had a belt drive Paxton blow through set up for a couple years on a street car. After fighting all the pressurizing problems I ended up building a pressure box to house the entire carb and although it worked it would have been better all around to move the carb in front of the blower.
steve fischer
Posted: 15 Apr 2015 at 8:04am |
sorry but this one does not blow or pressure the bowl, the turbo is after the carb,the part i was asking thinking about is all the fuel and air go through the turbo,fuel injection cars with turbo inject fuel with injectors after the turbo and only boost the air,will you get a dripping off of the turbo when putting the gas in it like water does on a diesel
Butch(OH)
Posted: 15 Apr 2015 at 8:35am |
Oh OK I succumbed to laziness and didn't check the link.
What you describe is called fuel fall out and yes you have reason for concern. Problems with it are more troublesome when there are long paths for the mixture to follow. Cooler weather and part throttle operations are when it will be most prevalent. Even it the system is sealed and it doesn't leak out somewhere fuel will puddle up. This causes a lean condition until you throttle up and then it will be stinking rich until the puddle drs dry up. Down draft carburetors and turbo up above the intake along with everything being as short as possible all help the situation. I have seen a lot of write ups on the Keystone turbos and you can read anything from the cats meow to pure junk. I suppose that depends on what the buyer expected of it and to be truthful a lot of idiots buy speed parts. ![]() One thing for certain if your tractor is barely getting by on 87 pump gas adding a turbo will cause you to be burning mid grade or premium and maybe backing down the timing. If I was considering a kit I would also be thinking about dropping the compression ratio a bit, then you can add some usfull boost and HP without getting into premium fuels.
PaulB
Posted: 15 Apr 2015 at 8:37am |
Funny: as I read the website, it's highlighted that "The carburetor and exhaust stay in their original location" That would have the turbo blowing through the carburetor.
Edited by PaulB - 15 Apr 2015 at 8:38am |
Zaddison
Joined: 19 Sep 2013 Location: Moweaqua il. Points: 174 |
Posted: 15 Apr 2015 at 9:29am |
45 turboa-
Joined: 04 Feb 2012 Location: coral city wi Points: 441 |
Posted: 19 Apr 2015 at 6:55pm |
I have a turbo on my WD45 works great! I built a manifold that looks like the one keystone makes.I've had the turbo on it for about 5 years I use the 45 all the time with no trouble.There is a video on youtube pulling a 4 bottom plow .
turbocharged
BPM75
Joined: 11 Jun 2011 Location: Greenup IL Points: 1050 |
Posted: 20 Apr 2015 at 12:44pm |
I've seen your video on there definitely gives the 45 a different sound, and seems to run good. |
59 D17 gas nf, 66 XT 190, 69 220.
