Key Switch - Adding Relays
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: Key Switch - Adding Relays
    Posted: 27 Jun 2019 at 1:00pm
Has anyone ever added a relay box to take the load off of the key switches on any Allis tractors?  My 7000 has been a little tough on key switches over its life (maybe 2 replacements in 11 years) and it seems the quality of switches has not improved over the years.  I know the MG guys with their Lucas electronics add them to take load off of head light, brake light, and ignition switches, just wondering if anyone had done similar to any Allis tractors?  I imagine this would pertain mostly to the 6000, 7000, and 8000 series.
Hurst
1979 Allis Chalmers 7000
5800 Hours
DougS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 1:57pm
Get the biggest Cole Hersee switch that will fit. Problem solved. A good 25 AMP DC-rated relay is every bit as big.
http://colehersee.com.au/product/anti-restart-ignition-switch-3-position/
Edited by DougS - 27 Jun 2019 at 2:02pm
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 1:58pm
Don't have any of the ACs you are asking about but we pretty well add relays
on our 720 garden tractors. Takes the load off the switches as you talked about and gets full power to the electric clutches. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
plummerscarin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 3:05pm
I have not to the stock harness but use relays and dedicated breakers for additional lighting I have installed.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 6:32pm
Hurst,
I have added relays for the light switch.   That's the switch that did fail multiple times on mine. (night time baling) Seemed to have solved the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2019 at 9:59pm
Ron,
I hadn't thought of those circuits, but definitely a good idea to at least add relays to the headlight beams, or replace them with LED's.  With all the crazies on the road, I think it may be worth while to look at doing a 7 pin connector and brake light retrofit, but that's getting a bit out on a tangent...
Hurst
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 6:48am
Its always an excellent idea to use relays in high load area's and circuitry. Take it from someone who's been building electrical systems for over 40 years. For systems that have a lot of load going out in different directions (starting with the "D" series Tractors) I offer a couple heavier Ignition switches to replace the somewhat boarder line OEM switch that came with the Tractor. The first few "D" series Tractors actually had a garden Tractor ignition switch in them! As time progressed, AC got a little better, but not much. Like any other mass produced item, whoever comes through with the cheapest price on the wiring and components got the purchase order. AC was no different from any other mfr. I keep in stock a 40 amp 11 bladed Ignition switch as an upgrade for the "D" series, and it would work well with any other application also. The same ignition switch I used in  one of the original Batmobiles that I had in the wire shop a couple years back. You can read about that on our website. Talk about relays and circuit breakers! There was enough wire in that vehicle to reach PA. One of the main reasons why the "D" series Tractors had so many wiring issues. Light components, and to light a wiring for circuit load especially when AC went to 12V. The 616-720 Garden Tractors benefit big time using relays in their systems because of load and length of circuitry that ran through the Tractor as Den mentioned. No matter what the system is in or on, relays are a big benefit to a healthy electrical system!  Thumbs Up
Steve@B&B
This page was generated in 0.285 seconds.
