Key removal |
wildcat2
Joined: 03 Aug 2011 Location: United States Points: 110 |
Topic: Key removalPosted: 03 Nov 2023 at 4:43pm |
Could someone tell me how to remove the key in this hub so I can remove it ? |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24787 |
Posted: 03 Nov 2023 at 4:48pm |
kinda depends on what it's on. at first guess a LOT of heat on the key, grab with vice grips, use claw hammer to pry vicegrips and key out. probably take several 'heat and pry' tries. any idea how LONG that key is ? I'd book 2 DAYS and be happy if it only took 1 !!!!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54468 |
Posted: 03 Nov 2023 at 5:37pm |
Looks like a tapered center hub. I could be wrong, need to see a little of a side view, to be sure. Soak with your favorite flavor of penetrating oil, then I'd hook up a pair of vice grips to a slide hammer and bang away, alternating with a few hammer licks to the outer portions of the hub, to ease frustration. Cussin helps, too...
![]() What is it, a wheel hub on a tractor?
plummerscarin
Posted: 03 Nov 2023 at 6:19pm |
I can't tell from that angle. Does it have a "L" shape on the end. If so, a Gibb(sp?)key. It is a tapered key. There is a special tapered tool for removing those. A chisel may work.I have also hit the sprocket in on the shaft which may loosen it. Heat may need applied.
dkattau
Posted: 03 Nov 2023 at 6:34pm |
Drive the hub onto the shaft about a 1/4 inch and that’ll take the tension off the taper on the key. Then you can pull the key out.
wildcat2
Posted: 04 Nov 2023 at 8:28am |
This on a #4 mower on an Allis G Tractor. The Shield Bracket mount broke and I have to take it off to put it back on after it is repaired. I figured the key had to come out to get the hub off. Never ran into this type off key and figured it had to come out before the hub would come off. Didn't know if I could put a puller on it and it would slide off. Didn't want to break the hub because it would be really hard to find another.
560Dennis
Posted: 05 Nov 2023 at 7:02am |
well I see that log bolts would work with a puller to pull the hub off . I use a torch and gently massage the hub with heat a few times and use puller to coax it free.
I see a center in the shaft . I always protect the center , I never damage the center if possibly removing any thing. May need to repair shaft on a lathe for example. I put a nut Between shaft and puller to push on keeping the center protected .
