keeping paint on muffler |
orangeman Ia
Joined: 24 Jan 2010 Location: Cedar Falls Ia Points: 77 |
Topic: keeping paint on mufflerPosted: 10 Dec 2010 at 7:07am |
How do you guys keep paint on mufflers? I "m using black paint that they use on headers, but it seems to flake off. The muffler is on a wd- 45. Thank you.
Chad(WI)
Joined: 11 Sep 2009 Location: NE Wisconsin Points: 958 |
Posted: 10 Dec 2010 at 7:14am |
How are you prepping the muffler? It has the be free from oil, and scuffing it lightly with emerey cloth will almost guarantee adhesion.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 10 Dec 2010 at 7:15am |
Flaking off usually points to the paint not bonding to the surface,at least that's my observations.
I've used VHT brand of paint, but used their primer first, then the color coat. I sanded it down real good,cleaned with laquer thinner, primered,painted.
VHT says you don't need their primer but...it does fill in the sand marks well,
Did this on a nice warm day last summer....so far ,so good.
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
Posted: 10 Dec 2010 at 7:23am |
I found with Hi-Temp paint, once the manifold is clean, I set it on top of the wood stove, get it warm, blast it with paint, then set it right back on the wood stove and bake it on. I usually hit it with 2-3 coats
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
orangeman Ia
Posted: 10 Dec 2010 at 7:50am |
Thanks guys I"ll use some of your methods you suggested.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 10 Dec 2010 at 8:20am |
It was on the local news a couple days ago that a garage blew up. It seems that a guy was painting a car, and the garage was being heated with a wood burning stove. He received 2nd and 3rd degree burns. Dusty |
Butch(OH)
Posted: 10 Dec 2010 at 8:43am |
For a work tractor? no paint stays on red hot muffler. For play machines we use BBQ grill paint from any hardware it works as well as any I have tried. Stays on except for red hot. Not a pretty black but looks better than rust.
KC-WD45
Joined: 11 Oct 2010 Location: Kansas City Points: 114 |
Posted: 10 Dec 2010 at 10:20am |
I used the same stuff Butch mentioned (BBQ paint) but first I removed the paint that came on the muffler when I bought it. I plowed with it this fall for 50+ hours and it still looks like new.
Brad MI
Joined: 12 Sep 2009 Location: Arcadia MI Points: 339 |
Posted: 10 Dec 2010 at 10:42am |
BBQ paint is also available in a couple shades of gray at some places. If you really need it painted to stay painted you'll need to send it out and have it ceramic coated, but I wouldn't spend the money.
Edited by Brad MI - 10 Dec 2010 at 10:43am |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5157 |
Posted: 10 Dec 2010 at 10:53am |
I use the rustoleum BBQ flat black on my pulling tractor pipe. It pegs the 1500 egt gauge, and the paint still looks great. I didn't even prep it very well, figuring it wouldn't last too long. It proved me wrong!
firebrick43
Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Posted: 10 Dec 2010 at 11:03am |
I have found on motorcycle and tractor mufflers that what DonDittmar says about getting it warm, painting, and baking it on works. I use an old electric oven. Also I found out, never mix brands of paint, they won't work with each other.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8759 |
Posted: 10 Dec 2010 at 1:56pm |
I put black bar-b-que grille paint on my pick-up exhaust manifolds about 25 years ago, and it held up, Darrel
Dans 7080
Posted: 10 Dec 2010 at 2:18pm |
I used bbq grill paint on the 7080 and 7060 pipes. I lightly sanded to get some of the loose rust off of them wiped them down with "prep-sol" and painted them. Pulling a ripper, disc, or whatever is behind them they are working. I have not had a bit of problem with the paint comming off at all.
