Kawasaki V, Tech Repair Ques |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Topic: Kawasaki V, Tech Repair QuesPosted: 25 Dec 2021 at 11:08am |
First off Merry Christmas all! Now to the Grench stuff. I have this Kaw V block ( FH601V-AS06) in a Toro Z. Yanked the motor to track down a nasty oil leak. So I have it hung on a hoist in the barn, cleaned up, to track the leak. Went out this am and a dark trail led me to the shaft (13107-7004). I call it the Gov shaft. It looks like it has a seal on it but not listed in my parts book. So I am going into the city to see if they can get that seal. If I can, is there a kinda short cut to work that seal out without taking the bottom of the engine off? If so and if I can get that seal, Maybe I will start believing in Santa again. ![]() So I know we got some small engine gurus here. Give me the good news first. Thanx
Joined: 11 Sep 2009 Location: illinois Points: 90811 |
Posted: 25 Dec 2021 at 11:46am |
best way i have found to remove a seal in a blind hole is to drill a small 1/8 inch hole in the steel face ( maybe 2 holes 180 degrees out). then screw a sheet metal screw into the hole.. grab with a pair of vice grips and PULL.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55278 |
Posted: 25 Dec 2021 at 11:52am |
Dave H
Posted: 25 Dec 2021 at 12:56pm |
Dang Dave, what an excellent video and he even gave the part number for the seal. Thanks for leading this ole horse to water.
Am hoping my seal comes out as easily, will see when the part arrives. I will post back in the future with I hope a success story. Thanks again, Dave |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25254 |
Posted: 25 Dec 2021 at 2:38pm |
man did you like his 'helpers' in the background ? roosters !!!
Dave H
Posted: 26 Dec 2021 at 5:00am |
Couldn't help but notice. Personally, me think that rooster was trying his best to keep those hens happy.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5188 |
Posted: 26 Dec 2021 at 5:45am |
Maybe I have a different way of thinking, bur the first thing I would wonder is what caused the seal to fail. Is there excess compression going into the base? Is there a vent plugged that is supposed to prevent pressure from building up? Is the shaft where the seal sits damaged?
Replacing the seal is only a temporary fix, if you don't find, and repair, the cause of the seal failure.
jaybmiller
Posted: 26 Dec 2021 at 6:09am |
hmm, great minds think alike ! I was wondering why the 'common' failure as well as I've never seen that on B&S engines(crankcase bolts loosen off though....) Be interesting to find out if the new seal FIXES the problem.
WF owner
Posted: 26 Dec 2021 at 7:07am |
When I tell my family that saying, the reply is usually "Apparently, simple minds think alike, too".
Dave H
Posted: 26 Dec 2021 at 8:57am |
speaking of crankcase pressure, there is an upgraded crankcase breather mod available that I am gonna put on while the motor is out. We will see. I will be surprised if it is totally fixed. We will see this spring.
