k361
AC puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Topic: k361
    Posted: 15 Nov 2015 at 4:21pm
does anyone know if the k361 18hp piston is the same as the 16hp?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2015 at 10:06pm
K 341 seems to be the same stroke as the 12 and 14 HP -just the bore size changes , so would think the bore would be larger in 18 HP but it is NOT - same size in both
Seems the specs are the same in both engines
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2015 at 12:11pm
Valves and Cam
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 6:38pm
I believe the skirt is longer on the 18hp piston. I had bought one several years back as it was improperly labeled for a K341. I sold it on ebay a few years ago.
Edited by ACmowerguy - 17 Nov 2015 at 6:39pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 7:20pm
stroke and pin hight may be diff. will check
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 7:41pm
  every thing is the same as 16 hp.--only difference is overhead valves--i have one i used for copetition-  only made 3 yrs.--used too beat the twins  also had more torque still have it in barn in a wheel horse
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2015 at 9:00pm
Read on a kohler site where the 16 and 18 were same bore. 18 had longer stroke.Cant find a rebuild kit piston rings,anywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2015 at 9:38am
quik look on part numbers they are all dif. but did not get into the actual measurements and specs.
This page was generated in 0.242 seconds.
