K2 grain header
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Topic: K2 grain header
    Posted: 02 Aug 2016 at 5:16pm
I need to pick up and haul 13ft. header off a K2. What are the proper lift points on it so I dont bend or fold any parts ? They have a loader tractor on their place and my trailer is prob. 30 in high. Chains , straps. rope???
Thanks for help !!
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 6:38pm
You should be able to put the bottom of the bucket under the lower latches and wrap a chain around the top of the throat opening. I have moved them that way before without damage
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 6:57pm
Thanks Dan , sounds like that would work fine . I wonder what a 13ft. header weights?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 8:03pm
Whether it has a series II wobble box flex sickle or a pitman arm drive with a hart/carter add-on fllex sickle, it will weigh more than a standard pitman rigid sickle. Without viewing my gleaner platform operators manual, I'm guessing 1500lbs for a rigid??
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 8:10pm
Thank you , it is a std. pitman rigid. I was guessing under a ton but really had no idea. thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 8:52pm
I had one on an F2 manual said 1839lbs.
Edited by Dans 7080 - 02 Aug 2016 at 9:01pm
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 10:29pm
I pick up and move all my heads (Gleaner) & (IH) with my ag crane, I just wrap a chain around/thru the throat opening and lift.  be careful if there are any hyd steel lines attached there so you don't crush them.
