Just bought an AC 7010 PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2023 at 7:31am
Have you had steering ram rebuild yet
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2023 at 8:17am
Top window coming out of the door? That usually means that the door frame is cracked right in front of the door handle. This causes too much flex when you shut the door. Weld it and perhaps reinforce it in that area. And lube that upper latch piece.
slowzuki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slowzuki Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2023 at 2:19pm
Ram isn't leaking internal or external, it's all in the orbital/steering valve.  Next time I'm near a scrap yard with some AC's I should pick one up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote slowzuki Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2023 at 2:21pm
The door frame absolutely is cracked there, good call, window came out shoving to attempt to get the door to latch open.  I saw a kit years ago to increase the opening angle and maybe add a gas strut to hold the door?  The doors easily the worst part of this tractor.  8000 series cab swap would be nice.
