Just about done, thought I would post a picture
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Topic: Just about done, thought I would post a picture
    Posted: 10 Oct 2010 at 8:11pm
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 8:14pm
very nice, love those diesels
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 8:17pm
Its a 55 model, I will get a better picture in couple days. I still need to  put on my belt pulley, fender light and hitch .
Edited by mark-east-tn - 10 Oct 2010 at 9:07pm
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 8:20pm
Very nice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 8:26pm
Nice job.   I have to ask a question since I've never restored one yet.  How do you paint the rims and not get paint all over the tires?   It seems to me that if you paint the rim first and then put the tire back on, it would get scuffed up from the tire spoons.   And if you try to tape off the tires, the tape never wants to stick.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 8:26pm
Purdy!
Greg Kroeker
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 8:28pm
Thats the way i like to see them ,the way they looked when new, very nice,I have one also ,a 55 model.thanks for the pic,
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 8:46pm
A film of vaseline is a good mask for the tires. Maybe not as hard on the rubber as chassis grease which also does that function. A soap film would probably work too, like concentrated dish washing detergent applied only to the tires and left to dry before painting.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 9:02pm
I always run a thin strip of 3m tape around rim, then I use a wide strip of 3m tape. Then I  use plastic  you can get from automotive paint store to go around tire with some more tape to hold it in place. But the trick to it is paint one side at a time ( usually I lean the tire and rim agianst the wall to paint.   hope this helps.......
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 9:19pm
I've heard tell of guys breaking the bead and then put your masking paper all around in the bead then air tire back up just till bead seats. after paint has dried break bead to pull out paper.
For me, if I'm using new tires, I just paint them without rubber. Then mount tires with tire lube. I can normally get them on by hand and only have to spoon one spot.
What did the mfg do?
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 9:24pm
Nice job. It's a good looking machine.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 9:34pm
In a farming mag Someone wrote in and suggested some flat aluminum flashing wrapped tight around rim.Never tried but sounds plausible.
