Just a matter of curiosity, irrigation
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Just a matter of curiosity, irrigation
    Posted: 04 Jan 2026 at 12:49pm
those irrigation systems that look like TV antenna towers laying on their sides, in sections supported by tandem wheel assemblies between sections, and tethered to a center well, or plumbing outlet.....how are they powered, and how is each section controlled speed wise, so that the system rotates around the center in a straight line?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 1:10pm
around here there use to be a couple diesel powered pumps ... but any more they drop a 480v line to a  base where the pump / electric motor and control panel set..
Edited by steve(ill) - 04 Jan 2026 at 1:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 1:50pm
Thanks Steve, that answers one question, but how do they co-ordinate all those drive wheels to create a circle? each drive assemble would need to travel at a different speed, depending on how far from the CenterPoint it is.
Wait for the Lord;
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 2:57pm
That's why they have people smarter than me. If I did it it would look like a coiled snake taking a wizz!
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 3:20pm
Each tower moves independently. There are limit switches that only let each one move so far. They are not always in a "perfect" straight line, but they are close. The speed can be controlled as to how much water they want put on the field. Most can be controlled from a cell phone nowadays. I am literally surrounded by them where I live. Valley, Zimmatic and T-L are the 3 major brands around here.
Edited by AllisFreak MN - 04 Jan 2026 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 5:26pm
Poor Ole farmers,,,,, getting those checks,,
Edited by DougG - 04 Jan 2026 at 5:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 5:33pm
Most Pivots around here have Water Driven Motors to Chain Drive Axle Wheels.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 5:47pm
To keep it simple, I'll start off by saying there are exceptions to most everything, and newer control systems that use computing power. Most in my area run on 480v 3 phase with a transformer to supply a 110v control circuit. The 480 is swapped at the pivot to run either forward or reverse. There are seperate wires that go out for the forward and reverse control circuits, and each span has a control box with a contactor for the 480 and two microswitches that run on a cam that is attached by linkage to the next span. one of the microswitches has the forward and reverse conrol cicuits wired into the normal open and normal closed posts, and the common runs the contactor. When the next span out moves far enough it trips the switch so it moves until the switch is open again. The other microswitch is the safety circuit, if for some reason things don't move it opens the circuit and the machine shuts down. Most machines 20 years ago(when I took classes) were built so if 110v was sent back to the pivot on the control circuit that wasn't being used it would reverse the machine. Speed used to be controlled by a simple timer, most made now use a computer and can be set up to change the speed in different areas of the field.
T-L macines run on hydraulic, and have flow control valves on each span to keep them aligned, and the only one I had much experience with used a flow control valve at the end to control the speed.
Again most of my information is from many years ago, and there are several exceptions. I hope this answers your question.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2026 at 9:09pm
Thanks for all the input. Like I said, just curious. Ted, pretty good explanation.
Wait for the Lord;
This page was generated in 0.150 seconds.
